Help USBport.sys Latency Issue Major Problem
Dissolution
7:01 PM
I have been having this strange memory leak for the past few weeks where my system will all of a sudden be incredibly bogged down, and the audio will start to crack and break as I am watching something or gaming. I thought it was a compatibility issue with my onboard sound, but I turned that off and the problem still persists. Today I was reading and I thought I would test my latency, and I found out that the USBport.sys is causing major latency issues in my system. The problem is that no matter where I look nobody has a real solution. Some have said that Windows released a patch for it, but when I tried to install the patch it told me that I already had it on my system..... Additionally, when I restart my computer it is generally fine for a day or two, but then it begins the cycle all over with latency problems.
I could really use some help to figure out why this is happening... I am open to any suggestions from anyone out there who might have some knowledge on this subject. I will try my best to provide any additional information that people may need to help me diagnose this issue completely. I should note that I have done a full virus/malware scan and found no issues. I have also updated all of the drivers on my board to see if that will fix the issue.
Thank you in advance.
Windows 7 64 bitIntel i7 3770k16 gig Corsair VengeanceAsus Nvidia GTX 680
Windows 7 64 bit
Intel i7 3770k
Sabertooth Z77
Asus Nvidia GTX 680
Seagate 1tb
I should also point out that I am using LatencyMon to monitor the latency in real time, and I literally just restarted and I am already getting issues with my audio. Something is definitely wrong, but I want to avoid formatting at all costs.....
Windows 7 64 bit
Intel i7 3770k
Sabertooth Z77
Asus Nvidia GTX 680
Seagate 1tb
Now I am getting this...
Windows 7 64 bit
Intel i7 3770k
Sabertooth Z77
Asus Nvidia GTX 680
Seagate 1tb
Open an elevated command prompt, type in sfc/scannow and hit enter. USBport.sys is a USB 1.1 and 2.0 port driver (Link) handled by Windows Updates so if there's a problem with the sfc/scannow may rectify it.
Report back with the results.
W7 Pro x64 SP1 | W10 Pro IP x64 | W8.1 Pro x6...i7-4790k @ 4GHz (4.4GHz Boost)16GB DDR3 Kingston HyperX Fury @ 1600MHz CL 9...EVGA GTX 980 Classified
Realtek Onboard
Samsung S27D390
240GB Intel 520 Series SSD |
Samsung 850 EVO 120GB SSD |
2TB WD Caviar Black |
2TB WD Caviar Green
Corsair HX850-80 Gold Modular
Cooler Master Silencio 650
Microsoft Sidewinder X4
Gigabyte M6900 optical
152mb
F-Secure
Firefox 38.0
Thank you. I am running the scan now...
In the meantime.... this is what Latencymon is showing...
Windows 7 64 bit
Intel i7 3770k
Sabertooth Z77
Asus Nvidia GTX 680
Seagate 1tb
Windows Resource Protection did not find any integrity violations... Sigh
Windows 7 64 bit
Intel i7 3770k
Sabertooth Z77
Asus Nvidia GTX 680
Seagate 1tb
Windows 10 ProAMD Ryzen 5 2400G Processor with Radeon RX Ve...G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-P...2047MB NVIDIA GeForce GTX 1060 6GB (EVGA)
Windows 10 Pro
Motherboard Built in
Wired Dell keyboard
Wireless Logitech mouse
250mb down, 30mb up
Panda Cloud Antivirus
Chrome-ish x64
I decided to update my system to Windows 8.1, but the problem seemed to persist through a complete wipe of my entire system. After updating every single driver I think I might have fixed it.... I still have a few errors that I am not sure of such as 1002 and 7000. The 1002 only happened once while I was playing Sleeping Dogs, and the 7000 error has only happened a few times. I am pretty sure the latency is gone though, but I am not sure how to check. I was told that LatencyMon is a bs program and not to use it. I haven't really noticed any drop outs since all the drivers have been updated..... how should I test it?
Any suggestions?
Windows 7 64 bit
Intel i7 3770k
Sabertooth Z77
Asus Nvidia GTX 680
Seagate 1tb
