Help with Graphics Card Compatibility Problem
Durfsurn
3:46 AM
Melbourne, Victoria, Australia
How can i find out if my ATI AMD Radeon 5450 Graphics card is compatible with my motherboard. My computer is a d530 MiniTower Convertible. My motherboard is 085Ch. The graphics card goes in the AGP Slot (I think thats what it is called).
Windows 7 Professional 32-bitIntel Pentium (Something)1 gbATI AMD Radeon HD 5450
HP d530
1 gb
1200 (or something) by 768 (or something)
40gb internal HDD
Logitec Wireless
Logitec Wireless
100 mb/s
i got my Radeon 5450 for $15 AUD! Ask me how!
Yeah apparently it is compatible.... Why are you asking? If it's already in it and you're linking a monitor cable from the card to your monitor then it's working...
Windows 7 Professional x64 SP1Intel Core i7 860 @2.80GHz6144MB DDR3-SDRAM (3 x 2048 DDR3)nVidia GeForce 310
Dell - Vostro 430
Dell 054KM3
nVidia GeForce 310
Realtek High Definition Audio ALC662
Dell Computer DELL E2311H
Seagate Barracuda ST3750528AS (750 GB)
J515T 350W
14.58inH x 6.69inW x 17.43inD
Fan from the Box heehee
Rapoo Wireless Keyboard
Rapoo Wireless Mouse
1 byte every 2.6 hours
Dreaming of building a new PC :D
Cant wait :)
i ask because my computer doesn't recognize it because it is using the integrated video card. Do you know how to disable it. I've tried going in to the BIOS and to no avail. It does not show up under display adapters in Device Manager. the olny thing showing up there is a standard VGA adapter which i disabled
HP d530
1 gb
40gb internal HDD
Logitec Wireless
Logitec Wireless
100 mb/s
It doesn't recognize it? So you plug in the cable from the card to the monitor and there's no display, and you're forced to use your onboard card? Or you still plug it in from the card to the monitor but it still uses integrated graphics?
Dell - Vostro 430
Dell 054KM3
nVidia GeForce 310
J515T 350W
Cant wait :)
The latter. Just a VGA cable btw. (That's the blue ended one right?)
HP d530
1 gb
40gb internal HDD
Logitec Wireless
Logitec Wireless
100 mb/s
Yep.
VGA - blue
DVI - White
HDMI - Black
So what you're saying is, you've checked that the VGA cable is linked from the graphics card to the monitor, but when you check Device Manager, your card doesn't show up?
Dell - Vostro 430
Dell 054KM3
nVidia GeForce 310
J515T 350W
Cant wait :)
Yep. I know I doesn't make sense to mme either.
HP d530
1 gb
40gb internal HDD
Logitec Wireless
Logitec Wireless
100 mb/s
Has your computer warranty expired yet?
If it has, then open it up and try taking the card out, cleaning the slot with compressed air and then putting the card back in again.
If the warranty hasn't expired (which I assume it hasn't, otherwise you'd have made this thread a lot earlier) then you should contact your computer manufacturer, because sometimes in their policy, they'll void the warranty if they detect that someone else has opened up your computer.
Dell - Vostro 430
Dell 054KM3
nVidia GeForce 310
J515T 350W
Cant wait :)
It is expired. I got it second hand in pristine condition. The man who sold it to me was an IT Professional. I will clean it an get back to you.
HP d530
1 gb
40gb internal HDD
Logitec Wireless
Logitec Wireless
100 mb/s
Good, remember to turn off all the power before opening it - pull the plug and hold down the "on" button for 30 seconds first.
Dell - Vostro 430
Dell 054KM3
nVidia GeForce 310
J515T 350W
Cant wait :)
Pull the plug after holding the on button right?
HP d530
1 gb
40gb internal HDD
Logitec Wireless
Logitec Wireless
100 mb/s
No.
Pull out the plug.
Hold "on" button for about 20-30 seconds.
Remove case.
Every 5 minutes or so (if you're spending a bit of time on it) touch a piece of metal (to remove any static electricity that might be building up on your body).
Remember, if you pull on the card and it doesn't come out straight away, check that you've taken out all the screws, locks etc. Once forced my old computer's GPU out and I snapped the board in half. :/
Dell - Vostro 430
Dell 054KM3
nVidia GeForce 310
J515T 350W
Cant wait :)
Done and you were a bit hasty back then...
Unfortunately that has changed nothing...
HP d530
1 gb
40gb internal HDD
Logitec Wireless
Logitec Wireless
100 mb/s
Still not recognising?
Try contacting the guy who sold it to you.
I can't think of any other solution :/
Dell - Vostro 430
Dell 054KM3
nVidia GeForce 310
J515T 350W
Cant wait :)
Hmmm. I don't think he will know. Anyone else on the forums know anything?
HP d530
1 gb
40gb internal HDD
Logitec Wireless
Logitec Wireless
100 mb/s
Hope someone helps you :)
Dell - Vostro 430
Dell 054KM3
nVidia GeForce 310
J515T 350W
Cant wait :)
Only other thing you can do is contact AMD or who ever made that particular card and start a RMA video cards are under warrenty for 3 years atleast and that series is barley 3 years old so i would look into replacing it via manufacturer
Enthod Pro Full Tower
Logitech wireless keyboard
Logitech wireless mouse
Cox Cable 100+ mb
IE-10, Chrome, Opera
GPU GTX Gigabyte 970G1
RMA?
HP d530
1 gb
40gb internal HDD
Logitec Wireless
Logitec Wireless
100 mb/s
Return to Manufacturer Assessment
That should be the proper term for that abriviation but i could be wrong but in any case it is used to report a bad product by manufacturer warrenty
That way it can be replaced with no cost to you if it is damaged and bad
Also your Board if it is AGP there is no way it would have fit in that slot Tottaly different interface
I would assume you are running Pci -e but your problem might be something else
Cox Cable 100+ mb
Return Material Authorization, I've usually seem it as.
(It means that the maker has authorized you to return a possibly defective product for inspection.)
If you're getting graphics when the monitor is connected to the graphics card, then the graphic card is working. It sounds like it's running with the generic (VGA) drivers.
AGP cards may be a little dicey with Windows 7. As your PC is from 2004, apparently, a little struggle may be expected. Good luck.
I suppose that you have something other than a 5450 (3450, perhaps?) as I doubt that there's a 5XXX card in AGP.
Have you tried these drivers?
AMD Catalyst
Windows 7 Pro X64 SP1Intel Core I7-3930k16 GB Gskill DDR3-2133eVGA GTX680
homegrown
Intel Core I7-3930k
Asus P9X79 Pro
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
