High Speed Connection - Low Speed Download?
eynestyne
5:19 PM
I have a 2Mb/s connection. At least that is what online speed test shows. But why are my downloads much lower? I mean less than 1Mb/s
Windows 7 Pro
Windows 7 Pro
Your connection is 2 megabits per second I assume....that comes out to about 256KB/sec in a browser.
Are you saying you only get 128KB/sec in your browser?
Windows 7 Ultimate x64Intel Q9550 2.83Ghz OC'd to 3.40Ghz8GB G.Skill PI DDR2-800, 4-4-4-12 timingsEVGA 1280MB Nvidia GeForce GTX570
Self-Built in July 2009
23" Acer x233H
Intel X25-M 80GB Gen 2 SSD
Corsair 620HX modular
Antec P182
stock
ABS M1 Mechanical
Logitech G9 Laser Mouse
15/2 cable modem
Yes, and lower. Just does not make sense.
Is something not configured right?
Windows 7 Pro
Windows 7 Pro
Well, one thing that matters is where the download is coming from in location to you. When you have latency on the line, your download speeds will never be as fast as they could be. For example, even if you had a dedicated 10mbps pipe to Europe from the US, at 200ms latency...the most you will get is 2.09mbps across that line. So, you only get 1/5 of your total speed simply due to distance.
23" Acer x233H
Antec P182
stock
ABS M1 Mechanical
15/2 cable modem
ok.. thanks for the info.
is there anything else that could be a cause?
Windows 7 Pro
Windows 7 Pro
^ yes, the ISP's (internet service provider) throttle the he:ol out the service.
WIN7 Ultimate, 64bit OEMi5-750 quad core8GB dual channel DDR3 @ 668MHZ (9-9-9-24) 4 x...ATI Radeon HD5750
homebuilt
i5-750 quad core
MSI P55-GD55 (MS-7589) (CPU1)
8GB dual channel DDR3 @ 668MHZ (9-9-9-24) 4 x 2GB each
ATI Radeon HD5750
onboard
LG widescreen LCD 1920 x 1080 FLATRON
2 x WD 500 GB SATA drives, room for 8 more in the drive bays. 1 WD USB 320 GB used for backup the system.
SEASONIC M-12D 850 watt sli ready
ANTEC DARK FLEET (biggest one they make)
case: 6 x 120mm fans 2 x 140mm fans, CPU: Corsair H50
generic
microsoft wireless
bloody slow thanks to Canadian ISP's throttling our net
soon to have a ZALMAN RESERATOR just for the GPU...also dedicated 500 GB of virtual memory for paging file,caching
mmmm, was hopin someone would not say that
Windows 7 Pro
Windows 7 Pro
This may not help, but have you tried unplugging your modem/router/both and plugging them back in? I have that problem on occasion mainly because of faulty hardware, but I would give that a shot.
Also, you could go to speedtest.net and test it with a server located near you.
Windows 7 Professional x64 | Ubuntu 10.04 x64Intel Core 2 Quad 2.66 GHz4 GBATI Radeon 3650 HD
Dell XPS 420
ATI Radeon 3650 HD
24" Dell Ultrasharp Display
Seagate Barracuda 750GB - 7200 rpm | Seagate Barracuda 80 GB - 7200 rpm
So all internet methods likes dsl/cable are affect by distance from you and your isp?
Win 7 & 10 x64Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz (...8GB DDR2HD 6970 2 GB
Acer M802
Win 7 & 10 x64
Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz (4 CPUs), ~2.7GH
MB.SCQ07.002 MB KIT G43 ICH10R HMII EUPLOT6 ECS R
8GB DDR2
HD 6970 2 GB
Realtek ALC 888s
AOC
1920x1080 60hz
WD Black 1 TB
WD My Book Essential 1 TB external HDD
Corsair TX650m
CM 690 II Advanced mid tower
fan
