Solved I need help diagnosing printing problem
MetalMan228
8:41 AM
Lancaster PA
Good morning all,
I am trying to print a page off that i have printed hundreds of times and now when the page prints (or any page now for that matter) the only thing thing that will print is a link contained on the page. In other words all that will print from a page is a highlighted link, none of the rest of the page will print. Nothing has changed in my pc, nor is this something that i have not done on my pc zillions of times before.
Please see screen shot. Blue highlighted link is all that will print. I tried other pages, same result.
Any help would be greatly appreciated
HP 505B B2C02UT Business Desktop
Windows 7 professional 64 bit
AMD Athlon(tm) II X2 220 Processor
PEGATRON (2A99)
3GB
Realtek ALC662 High Definition Audio (OEM)
OEM Dell CRT
N/A
(1) NCQ Smart IV 500GB Hard Drive - 7,200RPM - SATA 3.0Gb/s
HP LightScribe CD/DVD burner
OEM HP 300 watt
OEM
OEM
wired Logitech K120
wired M100 mouse
G5 High Speed Internet
ZoneAlarm Extreme Security
FF36.04 IE11
JRivers Media Center v17
AudioQuest dragonfly DAC V1.2
Mackie MR5 Studio Monitors
Does the link itself appear in blue on the screen without highlighting? Are you using an inkjet printer? If so, the answer may be an empty or clogged black ink cartridge(s).
Dell Inspiron 580s
Windows 7 Home Premium SP1
i3
ATI Radeon
Well, Yes and yes!! Wow, never had that happen before, but you are correct! Empty black ink.
I feel soooo 'tupid.....:o
PEGATRON (2A99)
3GB
OEM Dell CRT
N/A
OEM HP 300 watt
OEM
OEM
wired Logitech K120
wired M100 mouse
FF36.04 IE11
I'm glad the problem was easily resolved. Don't feel stupid; if it happens again, you'll suspect the cause!
Dell Inspiron 580s
i3
ATI Radeon
