I need help finding parts (capacitors) for a monitor.
Marshall Moore
1:16 PM
Anniston, Alabama
I have contacted HP. They say they can't help with this.
I need to find out what capacitors fit my HP 2509b monitor. My monitor is flickering and I would like to replace the bad capacitors. I would like to know what possible capacitors are inside of the monitor and order them bad or not. They aren't expensive so if I buy some I don't need that is fine. I would like to have them on hand when I take the monitor apart so I can replace the bad ones at the same time. I would rather do it that way verses taking the monitor apart to find out what capacitors I need and then ordering. I have had no luck searching the web for this information. Please let me know what to order so I can repair my monitor before it goes out completely. Thank you, Marshall Moore
Windows 7 Ultimate x64Intel i7 2600KG.SKILL Sniper Series 16GB (4 x 4GB) 1866Gigabyte AMD Radeon HD 7870 GV-R787OC-2GD
Intel i7 2600K
Gigabyte Technology Co. - Model GA-Z68X-UD5-B3
Asus Xonar Essence STX
HP 2711x 27 inch
SSD OCZ Vertex 4 256 GB
Western Digital WD3001FAEX 3TB 7200 SATA 6Gb/s 64MB
HDD 1.5T|HITACHI 7K3000
CORSAIR Professional Series HX650 (Modular)
CASE ZALMAN | Z9 R
COOLER MASTER Hyper 212 EVO
Logitech K800 Illuminated Wireless
Logitech M600 Touch Mouse
Norton Internet Security
WaterFox 64 bit
Audioengine A5+ w/S8 sub and Audio-Technica ATH M50 headphones
Your best bet would be to take the monitor apart and find/locate the bad capacitors and get the ID# off of it and look it up that way. I here Radio Shack has a good inventory of such items.
Windows 7 Ultimate 64 bitAMD Phenom II X4 965 Black EditionGSkill 4 X 2 GB PC 8500XFX Radeon HD 6790 D
Custom built
Gigabyte GA-MA790X-DS4
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
You are probably right. That way I can go ahead and fix it the same day. I didn't want to take it apart and have to order the capacitors and wait for them. Good sound advice. Thank you.
Intel i7 2600K
HP 2711x 27 inch
CASE ZALMAN | Z9 R
WaterFox 64 bit
If they are regular electrolytic capacitors, the value will be right on the caps. IE: 10mf 10v (10 micro farads at 10 volts). These will be common, and likely available at RS unless they are some strange value. It they are another type of capacitor then they would likely only be identifiable by the location in a service manual, such as c910, cross referenced to a part number.
What makes you think it is capacitors? The common capacitor issue (see Capacitor Plague ) usually affects power supplies, and results in trouble turning the unit on. They certainly can have other effects. Is the video flickering only, or are the backlights flickering? Look in the back through the cooling slots and see if the lights are flickering.
Go here and scroll down to Screen flickers, unstable image
http://h10025.www1.hp.com/ewfrf/wc/...loc:1&cc=us&dlc=en&lc=en&product=5074282#N403
Does that look like it?
A Guy
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
ANTEC Three Hundred Illusion
85 + Mbps
Vivaldi
Monitor is flickering
I know it is only a monitor issue. It is flickering. With the monitor disconnected from pc it still flickers. It will stable out after a few seconds. I was only wondering if someone would know how or if I could find out what capacitors are inside without opening it up first. Capacitors are fairly inexpensive so I wanted to buy all possible compatible capacitors without having to physically inspect them first. In a nutshell I didn't want to have to take the monitor apart spot which ones are bad and then order the replacements. If I already had all possible capacitors on hand I could just fix the monitor in an hour or two, thus keeping the down time to a minimum.
I know whats wrong with the monitor. I just was hoping someone may know how I could find this information with research rather than with inspection. Thank you
Intel i7 2600K
HP 2711x 27 inch
CASE ZALMAN | Z9 R
WaterFox 64 bit
OK...I am a TV tech, but don't have access to any HP manuals (not sure who makes their stuff). You may not be able to physically see which caps are bad. But looks like you have that covered, so wish you luck ;)
A Guy
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
85 + Mbps
Vivaldi
