ideas: Laptop to power on when there is power
cyberrock
4:39 AM
Hey guys,
Im normally pretty tech savvy though i am stuck on a problem.
I often have my laptop plugged in to an inverter, plugged in to the car. I need it to power on by itself, when there is power from the inverter.
Any ideas?
regards
ben
N/A
N/A
Hey guys,
Any ideas?
regards
ben
Do you mean you need to power it on by pressing such a power button, maybe located in elsewhere on your laptop?
Self Assembled
LG Flatron E2040T
1600x900
Western Digital 1 TB
Seagate 500 GB
Corsair VS550
Cooler Master K380
Logitech MK260r
Logitech MK260r
PMPL Broadband
Windows Defender + MBAM
Dell Studio 15" Laptop
no, just when it has power from a 240v socket
N/A
N/A
Two things.
1. I know of no computer that uses 240 volts as in your post #3
2. I know of no way a computer can start itself from a cold boot.
What kind of car do you have that has 240v that you want to convert to proper computer volts?
From post #1
Things are not adding up.
1) Australian standard residential power supply is 240volts.
2) Hense my questions on this forum. "DOES ANY ONE HAVE ANY IDEAS..."
3) if you do not know what an "inverter" is (as stated in my first post), then you wouldnt be the right person to to help with this query
Thanks any way
N/A
N/A
They are talking about the mains power Jack, 240V in AUS.
Here's an inverter that will go from 12V to 230V
Halfords | Ring PowerSource Inverter 75W
What they are trying to do is have it power on as soon as it gets power instead of having to use the power button, an instant startup once it gets power.
Win 10 Pro x64
Intel I5-2500K @3.3GHz
Asrock P67 Extreme4
EVGA GeForce 750 Ti SC 2GB
auria eq2367
250GB Samsung 850 EVO SSD
1TB WD Blue
1TB Hitachi
SeaSonic X 650W 80 Plus Gold
Corsair Obsidian 750D
Logitech Wireless Mouse M310
Wave Broadband ~ 100 dn 5 up
Edge, IE11, Chrome
Laptop specs: HP g7-1365dx /
RAM: Crucial 8Gb (2x4Gb) /
GFX: AMD Radeon HD 6520G /
OS: Windows 10 Pro x64
I already have an inverter as stated in my first post.
But this is spot on. Yes.
N/A
N/A
Win 10 Pro x64
Asrock P67 Extreme4
auria eq2367
1TB WD Blue
1TB Hitachi
Edge, IE11, Chrome
Thanks derekimo for the information about the home voltages.
All the members we have from Australia you think I would of known that. Now I do.
I will wait for the answer for the Auto Push Power Button from a cold boot.
I like learning new things.
Win 10 Pro x64
Asrock P67 Extreme4
auria eq2367
1TB WD Blue
1TB Hitachi
Edge, IE11, Chrome
yea what I would do in this situation I would find a universal cig charger. the have built in inverter and won't put a strain on your cars charging system. then I would hard wire it to the the fuse box so it would take up the space of my cig charger
windows 7Intel Atom 1.66GHZ Dual Core1gINTEL GMA 3150
windows 7
1g
INTEL GMA 3150
iMo Pivot 7" touch
SATA 2.5' 250g Samsung Hard Drive
touch screen
touch screen
300 mbps wifi
Found this too,
Win 10 Pro x64
Asrock P67 Extreme4
auria eq2367
1TB WD Blue
1TB Hitachi
Edge, IE11, Chrome
as stated above in the video you could wire the current inverter you have to a fuse on the cars electric system that's tied into the ignition or after the car is running. year make and model
windows 7
1g
INTEL GMA 3150
iMo Pivot 7" touch
touch screen
touch screen
300 mbps wifi
You will only find the BIOS option to restart after power off in Desktop system BIOS. Laptops do not have that BIOS option.
Bill
Windows 10 22H2 ProIntel(R) Xeon W-10885M2x 32 GB DDR4 ECC memory (128 GB max)Intel onboard GPU 1080p - Quadro RTX 5000 Max...
Dell Precision 15 7550 Workstation
Windows 10 22H2 Pro
Intel onboard GPU 1080p - Quadro RTX 5000 Max-Q GPU 4K
1TB Samsung 9100 Pro main M2 SSD
2x 2TB Samsung 9100 Pro temp storage M2 SSD (6 TB max)
Logitech MX-25 Bluetooth
slow
MS
Pale Moon 34.x.x - x64 AVX2 build
