Loud Fan Noise if using Utorrent and Media Center.
lornaevo
8:39 AM
Hey Guys, I have a HTPC that I use only for Media Center and Utorrent. Most times when I am using it it makes loud noises. I think it's the fan trying to cool it down. The case is open and it has pretty decent specs. I don't know what else to do.
Here is a copy of my Cpu Z
Windows 10Intel Core i7-4790 Processor 3.6GHz12GB DDR3 1600NVIDIA GeForce GTX 760
Acer Predator G6
Windows 10
Intel B85 Express
12GB DDR3 1600
27" Monitor
2TB Internal
Hoping to add a 32GB SSD for OS
FIOS 50/50
stop using torrent programs.
MS Windows 7 Ultimate SP1 64-bitAMD A10-4600M6.00 GB Dual-Channel DDR3 @ 798MHz (11-11-12-28)AMD Radeon HD 7660G
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
Acer Predator G6
Windows 10
Intel B85 Express
12GB DDR3 1600
27" Monitor
2TB Internal
FIOS 50/50
Such as?
Im curious.
Windows 7 Home Premium 64bitIntel Core i7 2700k8GB Mushkin Redline Ridgebacks @1866EVGA GTX570 SC
Custom (Self Build)
Intel Core i7 2700k
eVGA P67 SLI
EVGA GTX570 SC
XiFi Titanium HD
LG W2453V
Seasonic x750
Corsair 600T SE White
eVGA Superclocked CPU Cooler
Saitek Cyborg
Kaspersky
IE
LG BD/DVD
If you're using a program that is for transcoding and encoding, that you downloaded, those programs are CPU intensive.
CPU heats up, PC gets hotter and the fans kick in.
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Acer Predator G6
Windows 10
Intel B85 Express
12GB DDR3 1600
27" Monitor
2TB Internal
FIOS 50/50
@lornaevo:
Even though there may be legit reasons to use it Malware absolutely LOVES to be hidden in that stuff. You're begging to be infected. :devil:
win 7 home premium 64 bitcore i5 7606 gbati 5450
hp pavilion 6680t
core i5 760
iona (from MSI)
6 gb
ati 5450
real tek 888
Stop posting your useless 'advice'. FFS. If you can't be constructive, don't post.
And people can stop with the malware comments etc - it's a tired argument. After literally thousands of torrents, I have never been infected - not once. If you listen to the naysayers, I should be a walking virus factory...
And yeah, torrents are also used for legitimate purposes :sarc:
µtorrent uses bugger all CPU so your biggest culprit here is most likely media center. The fan is ramping up under load. I assume it's stock?
Is the PC noisy when only one of the two apps is running? Or is the PC noisy just running µtorrent?
Systems by SmartEyeball
8 Pro x64
i7 3770K 4.6GHz
ASUS P8Z77 WS
x3 Dell U2410 / 58" Samsung
5760*1200/ 1920*1200
Noctua NH-D14
IE, FF, WaterFox
Bloody Big Grin
Smarty:
I don't want to go too far OT, or be disrespectful, because you have lots more experience than me for sure, but not everyone is as well informed or skilled at knowing where to go and what to look for when using them. So do you have any suggestions for the rest of us that will help us to avoid any potential problems with torrents?
B.
hp pavilion 6680t
core i5 760
iona (from MSI)
6 gb
ati 5450
real tek 888
First step:
You can open task manager and see what process is taking up much CPU cycles when the fan starts. Identify the program which is causing it.
Install CoreTemp and see the CPU temperatures at this condition.
You say the case is open and well ventilated... Which fan is kicking in.... CPU fan or Case fan. If it is case fan and making lots of noise when working, you can as well disconnect it (Case is open and there is fresh flow of air). Try to keep the system in a well ventilated area, (not in a cramped space which obstructs air flow and causes problems). Or replace the fan with a new one which is silent.
If it is CPU fan, check the heat sink of the CPU and see whether it is choked with dust (reason being open case). Clean the Heatsink with compressed air and a brush. The CPU fan kicks in during intense CPU cycles when there is'nt enough air flow through heat sink, causing the sensor to start the CPU fan. The CPU fan also should be silent when operating. If it is making lots of noise (due to wear and tear), better replace it.
One more possibility is the SMPS (power supply) fan. If the SMPS becomes old and the fan is worn out, this also makes lots of noise. Better replace the SMPS if it is so. Also look for any loose parts in the case. They may add up to the fan noise by increasing the vibrations. Tighten all the screws in the case. Sometimes this works.....
MS Windows 7 Ultimate 64-bit SP1i5-2410M 2.3GHz (2.9GHz Turbo-Boost) Sandy Br...4GB+4GB Samsung DDR3 PC3-10700 (1333 MHz)Video Intel(R) HD Graphics Family, 1696MB ava...
Toshiba Satellite P775-S7232
i5-2410M 2.3GHz (2.9GHz Turbo-Boost) Sandy Bridge 32nm
Toshiba PHRAA ver. PSBY1U-00F003
Video Intel(R) HD Graphics Family, 1696MB available memory
Realtek High Definition Audio version=6.0.1.6323
17.3 " Trubrite TFT LCD, LED Backlit
1600x900 32 bit, Native support for 720P content
TOSHIBA MK6476GSXN
580.614 [GB] partitioned C: 80GB and D: 500GB with hidden recovery partitons.
Spare bay for 2nd HDD but no SATA connector :-(
Toshiba AC/DC Adapter
Notebook
Built-in Fan
Premium Raised Tile keyboard
Logitech M215 wireless mouse
Not fast enough
Built-in Harman Kardon speakers with Dolby Advanced Audio, Waves MaxxAudio® 3. HDMI, 1xUSB3+3xUSB2 ports, WebCam, Battery life 4hrs 11mins, 4GB Readyboost SDHC card, WD My Book Essential Ext HDDs 2 TB, 2x1TB, My Passport SE 1TB and WDTV 1st Gen for Multimedia playing on a Sony Wega 32" LCD.
Recent addition to my toys are Asus Transformer Pad TF300T with 32GB onboard sd card + 32GB microsd card.
Acer Predator G6
Windows 10
Intel B85 Express
12GB DDR3 1600
27" Monitor
2TB Internal
FIOS 50/50
That's correct I don't know much about them except many get infected with them. You haven't got infected yet using it and that is a good thing.
I regards to torrents, I have just 1 simple, question.
If its being used for legit reason, why not just go to the official site and get it there via direct download, rather than torrent which is often slow and then seed it for a long period of time.
I do know a few places offer thier goods via torrent or direct DL, and direct is almost always faster.
Just seems to me theres really no incentive to use it, even for legit reasons.
At any count, we are getting off topic.
Have you tried the previous suggestion?
Stop the torrent app, and start MC. Does it still do it with just MC running?
As far as the noise.. is it a fan spinning up or HD? Or can you tell?
Look at the HD activity light and see if its staying on if not sure.
One possiblity could be a large collection which has not completely been indexed into the library.
Maybe thats part of it. If this is the case, just leave it alone for a few minutes and it should fix itself soon.
Custom (Self Build)
Intel Core i7 2700k
eVGA P67 SLI
EVGA GTX570 SC
XiFi Titanium HD
LG W2453V
Seasonic x750
Saitek Cyborg
Kaspersky
IE
LG BD/DVD
