My Monitor goes to sleep after 10 minutes, screensaver none, power....
Axely
12:34 PM
hello i am new to the forum, Well i am getting really frustrated that my monitor goes to sleep after 10 minutes of inactivity, but my computer still runing,video still playing, music still playing, just my monitor decided to go to sleep for no reason, and i have to move my mouse to get it wake up again. i have set my screensaver to off, and power option to never, and it is still happening. i might not be the only one here having the same problem, if anyone have any solution that could help me out please do , i will really appreciate it ;c :cry:
windows 7 professional x64
Hi welcome to the forum
what do you have your monitor to do after a certain time? go to control panel power options on left hand side of screen choose when to turn off the display
win 10
dell xps 9000
win 10
its set to never alreaady, but still getting the same problem
bump
advanced
Hi Axely,
I use high power option, with these options, give them a try
Roy
E5300 dual core
medion MS7366
3gb
avixc
n (isp resticted to 72)
mse/pands
palemoon
hmm weird, i do not have that option "multimedia setting"
high
Did you look at the
HIGH performance section, of power options, NOT balanced.
Roy
E5300 dual core
medion MS7366
3gb
avixc
mse/pands
palemoon
yes i did
Can you try another monitor or if monitor has another type of input try that.
win 10
dell xps 9000
win 10
settings
Hi Axely,
I've put a call out regarding the fact you dont have those multimedia options. Unusuall
Do you have Windows media player installed, or any other, ie VLC
Please fill in your comp specs Make/model/ graphics card etc, it will help
Roy
E5300 dual core
medion MS7366
3gb
avixc
mse/pands
palemoon
Yes, please fill in your system specs especially the make/model of your display monitor. TW I have multimedia even with the balanced setting
Some monitors will have their own sleep settings, but we can not guide, if we do not know.
Originally Win 7 Hm Prem x64 Ver 6.1.7600 Bui...Intel i3 530 2.93GHz, 2933MHz 2 Cores 4 Logic...6GB of 1,333MHz DDR3 SDRAM32MB Intel Graphics Media Accelerator HD IGChip
Gateway H57M01 133 megahertz
1600 x 900 x 59 hertz
300watts.
Mid-Tower Desktop
Stock from Gateway
System Specs by Belarc.
Canon Pixma MG3222 Printer.
Win 10 Pro x64
Intel I5-2500K @3.3GHz
Asrock P67 Extreme4
EVGA GeForce 750 Ti SC 2GB
auria eq2367
250GB Samsung 850 EVO SSD
1TB WD Blue
1TB Hitachi
SeaSonic X 650W 80 Plus Gold
Corsair Obsidian 750D
Logitech Wireless Mouse M310
Wave Broadband ~ 100 dn 5 up
Edge, IE11, Chrome
Laptop specs: HP g7-1365dx /
RAM: Crucial 8Gb (2x4Gb) /
GFX: AMD Radeon HD 6520G /
OS: Windows 10 Pro x64
