Hi everyone,
I recently purchased a new HP PC w/ Windows 7 Home Premium [64-bit] OS.
When I ordered this computer from HP, it was supposed to come with a wireless internet card. However, the manufacturer made a mistake and did not install any card. I called and complained, now HP has sent me the following product:
Linksys WMP600N Dual-Band Wireless-N PCI Adapter
Is this card any good? Do I need t watch out for any problems?
I guess the bonus is I only had to pay $5 for it.
Now onto setting up the connection....
I did install a NETGEAR wireless card on the back of my old PC, about 6 years ago, so I think I should be able to install this card, however I did read some people have problems with the drivers on this card. Also, at my old apartment where I had wireless internet the first time, the landlord and maintenance people managed everything for providing the signal, so I don't really know anything about setting up router, signal, connection, etc.
Help would be appreciated!
Right now the primary internet connection in this house comes through the cable+phone company. There is an RCA Thompson Digital/Broadband modem or router or something, model #DHG535-2, and from there the connection plugs through ethernet cable into the Apple Mac that I'm using to type this right now.
My new PC is in another room, and I will install that Linksys wireless card and use that PC most of the time. What I would like help with is:
1. What steps must I take to install the new PC
2. Do I need to get a wireless router, and if so, which ones will work best with the wireless card I received
etc. etc.
I think I found my old NETGEAR wireless router, model number MR814v2(??), but I bought this 6 years ago and don't know whether it will work well or at all with the new dual-band card.
I also don't know what to do about the RCA thing hooked up to the Mac and telephones, none of those are mine, so I'm not sure about taking them out and doing away with them if necessary, etc.
Just a little confused how to get this connection up and running, help appreciated! Thanks!
etc. etc.
Windows 7 Home Premium [64-bit]Intel i3-2120 [3.3GHz, 3MB cache]6GB DDR3-1333MHz SDRAM [2 DIMMs]1GB DDR3 NVIDEA GeForce GT520
- HP p7-1270t
- Windows 7 Home Premium [64-bit]
- Intel i3-2120 [3.3GHz, 3MB cache]
- Motherboard
- Pegatron IPISB-CU (Carmel2); Intel H61 chipset
- 6GB DDR3-1333MHz SDRAM [2 DIMMs]
- Graphics Card(s)
- 1GB DDR3 NVIDEA GeForce GT520
- Sound Card
- Integrated HD Audio; Audio CODEC: Realtek ALC656GR
- Monitor(s) Displays
- HP 2211x 21.5" LED
- Hard Drives
- 1TB 7200rpm SATA
- PSU
- 300 Watt
