Solved Need help USB 2.0 to vga dual monitor connection
mcrump
8:10 PM
Okay I was told connecting the USB 2.0 to vga cable to my monitor and laptop would be easy but it has not.
I have an LG Flatron E1942 monitor with a vga/dsub port in the back. My laptop is an xps L502X with2 USB ports and an hdmi port.
I have a USB 2.0 to vga cable from cables to go.
Issue: I installed the drivers all fine but once my computer restarted the monitor remained black OR both monitor and computer remained black OR only my background image would display on my laptop (I've rebooted countless times). When the monitor is the only one black I can still move the cursor over to it but that is all I get.
I am so frustrated. Could anyone help me please?
FYI I tried an hdmi to vga cable once and nothing worked there either.
Windows 7 home premium 64 biti7-2820QM
i7-2820QM
Norton
Internet explorer, Firefox, Chrome
Did you extend your desktop across to the second monitor? Press the Windows key and the P key then select Extend. Do you have a link for the USB 2 to VGA cable? It sounds like that is an external USB 2.0 video card.
Windows 10 Education 64 bitAMD Phenom II X4 980 Black Edition Deneb 3.7GHz8GB 4GBx2 Kingston PC10600 DDR3 1333 MemoryZotac NVIDIA Geforce GT640 2 Gig DDR3 PCIe
Home Built
Thermaltake TR 620
Stock heatsink and fan
Logitech Wireless K350 Wave
80 Mbps Down 30 Mbps Up
Windows Defender
Internet Explorer 11
I have extended it and nothing happened...both are black screens right now. Once I unplug the cable my laptop goes back to normal.
i7-2820QM
Norton
I should add its an adapter not a cable
i7-2820QM
Norton
OK, its letting you extend so Windows is seeing the adapter and monitor but other than that I'm not sure what's going on. Anything in device manager with a yellow ! and does that adapter show up there correctly identified?
Home Built
Thermaltake TR 620
Windows Defender
There is no ! And it is showing up on the list correctly
i7-2820QM
Norton
OK, Hmm, Were there any utilities/programs installed for it with the drivers? If yes have you run them?
Home Built
Thermaltake TR 620
Windows Defender
It's a plug it in and the drivers automatically download adapter
i7-2820QM
Norton
Have you tried that adapter on another PC? Maybe its defective? Does it have its own power pack, maybe its not getting enough power from the USB port to run? That can happen on some laptops if the USB port doesn't supply the full 500ma.
Home Built
Thermaltake TR 620
Windows Defender
I was snooping around and changed the bit colour and now it's working fine thus far
thanks for helping me alphanumeric. I appreciate it.
i7-2820QM
Norton
