Need Help With My Sound?
Yankie007
Power User
2:43 AM
New-Brunswick, Canada
I just bought a second monitor and when I plugged it in the HDMI behind my Desktop Computer, I lost all my sound and if I unplug it, the sound comes back! The reason I use a HDMI is because I don't have a DVI cable and there is only one spot for VGA (already used). My question is how to enable sound for both monitors?
Thanks in advance,
Yannik
Ps:
My other question is quite simple: Is it possible to purchase a wireless keyboard but still use a wire mouse?
Windows 7 Home Premium 64bit.
Intel Core i7 CPU
Gigabyte X58A-UD3R
6.00 GB RAM
ATI Radeon HD 5700 Series
Creative Sb-X-Fi
Acer 24 inch
1400 X 1050
1 Tb
NZXT Mid Tower
Kensington Expert Mouse
Cable
Windows automatically, as you have found out, changes the Default audio playback device from "Speakers" (PC Sound) to "HDMI" when an HDMI cable is connected. You can manually change it back to "Speakers".
I don't use HDMI so I can't verify but I was told if you disable the HDMI audio in the Device Manager that it will not switch the sound. Give that a try.
Second question. Yes, you can use a wireless keyboard with a wired mouse. Both are separate connections and functions.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Thank you so much for the help. As for the sound, I went in device manager although I can't locate what you said about disabling the HDMI audio! There is a thing called: Sound, video and game controller:
AMD High Definition Audio Device
Beat Wireless (Mono Audio)
Beat Wireless (Stereo Audio)
Creative SB X-FI
Hauppage Win
HD WebCam C525
I don't know how to disable it from there?
Intel Core i7 CPU
Gigabyte X58A-UD3R
6.00 GB RAM
Creative Sb-X-Fi
Acer 24 inch
1400 X 1050
1 Tb
NZXT Mid Tower
Cable
The "AMD High Definition Audio Device" is the HDMI audio and the one to disable. RIGHT click on that entry and then LEFT click "Disable".
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I use external speakers and HDMI and all I do is select the speakers here as Default.
Intel Core i7 CPU
Gigabyte X58A-UD3R
6.00 GB RAM
Creative Sb-X-Fi
Acer 24 inch
1400 X 1050
1 Tb
NZXT Mid Tower
Cable
