Hi everyone, first post so please bear with me.
I just bought a new PC: HP p7-1270t w/ Windows 7 Home Premium [64-bit] OS.
The sound is way way too low!
On my old computer, I had 10 year old Polk speakers that, with the settings on max, the sound did reverberate through the entire house. I plugged those same speakers into the new machine, and even with volume settings on max, the noise is barely audible. Yes, it's there, but if you want to listen to music or watch DVD's or web content, the sound is completely unacceptable.
Please help!
I've done things like change from Night mode to theatre mode, no difference. I enabled loudness equalization or whatever it is, no difference. I played with the wave bars on media player, and yes I did notice a small difference, but again still completely unacceptable.
I would like to know possible problems/solutions. Do I need to download new codecs or anything to make the sound louder? Update driver? Could I have bad hardware components, bios etc? I do plan on buying new speakers, I see on the web some threads about independent power speakers, but to be honest I'm skeptical of this, because the 10 year old speakers I have worked just fine on my old Windows XP computer.
Thanks!
Please help!
Thanks!
Windows 7 Home Premium [64-bit]Intel i3-2120 [3.3GHz, 3MB cache]6GB DDR3-1333MHz SDRAM [2 DIMMs]1GB DDR3 NVIDEA GeForce GT520
- HP p7-1270t
- Windows 7 Home Premium [64-bit]
- Intel i3-2120 [3.3GHz, 3MB cache]
- Motherboard
- Pegatron IPISB-CU (Carmel2); Intel H61 chipset
- 6GB DDR3-1333MHz SDRAM [2 DIMMs]
- Graphics Card(s)
- 1GB DDR3 NVIDEA GeForce GT520
- Sound Card
- Integrated HD Audio; Audio CODEC: Realtek ALC656GR
- Monitor(s) Displays
- HP 2211x 21.5" LED
- Hard Drives
- 1TB 7200rpm SATA
- PSU
- 300 Watt
