Pagefile constantly going crazy - please help
Is that motherboard Dual Channel (2 or 4 RAM slots, not 3 or 6), then yes you need a 4th stick and you are taking a performance hit using 3.
If it's triple channel (a dead technology) then the 3 1gig sticks are correct.
I suggest using 1024 min max page file.
If it was on another HD the OS is not on, not just partition, that is best, although I would avoid it on SSD due to finite # of writes.
Self Built Custom
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was required!
MSI 890FXA-GD70
8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo nonOC max rec'd]
Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Frozr model
Realtek High Definition Audio (onboard mobo, ALC-889 chip)
2 WS LED Monitors: One LG One Viewsonic
1920 by 1080
SSD for OS: Samsung 840 Pro
SSD for VM and utilities: Adata SX900
7200 RPM SATA HDs for the rest: Hitachi and Seagate
Corsair TX850 - 850W max, in service since August 2010.
Thermaltake Armor A90
Thermaltake Spin Q CPU Cooler, in service since August 2010
Logitech G11
Logitech M310 Wireless
100 Megabit broadband supposedly upgraded from 50 (Cable)
Bitdefender Internet Security 2014 suite
Pale Moon 64-bit main, also IceDragon, Opera, and Maxthon.
CompTIA A+ certified (220-800 series) in July 2013.
Asus P6T Deluxe v1 is triple channel
Yup - triple channel.
Wow - the 1024 number is much smaller than the ~4500 that was mentioned earlier in the thread (1.5 times the amount of RAM). may I ask why I should set it lower, to 1024? Does a smaller pagefile offer a benefit over a larger one?
custom build
Windows 7 32bit Home Premium
Intel Core I7 920 Bloomfield
Asus P6T Deluxe v1
3 GB Corsair DDR3 (3x1GB)
NVidia GTX 570 (1 GB RAM)
on board
Dell P2314H
Western Digital Black 1TB (main OS)
XION Supernova XON-800R14N 800W
Antec 1200
Arctic Freezer 7 Pro Rev. 2
AZIO Prism
Logitech G700S
Verizon FiOS 85/85
Firefox/Chrome
SansDigital rr622 RocketRaid (with non-raid Driver)
Renesas USB 3.0 card
The smaller the better, you want windows using actual RAM as RAM, not much slower hard drive space as RAM.
I start at 1024 and if that works fine (expected) I'd not change it.
Letting Windows decide the virtual memory size could result in an often re-sized file, and fragmentation, 1024 should be plenty for most.
I suggest 0/0 min max, reboot, defragment the HD it's going on, and then 1024/1024 min max it and reboot again.
That was a much more critical helper with older windows versions with less RAM.
I also knew that the Intel 9xx CPU series was the last one using triple channel, it was a possible A+ exam fact.... muhahaha!
Self Built Custom
MSI 890FXA-GD70
1920 by 1080
Logitech G11
Okay, thanks. That makes sense - that's what I wanted - for Windows to use my available memory instead of paging everything back and forth like it does. I'll give that a shot.
custom build
Asus P6T Deluxe v1
on board
Dell P2314H
Antec 1200
AZIO Prism
Logitech G700S
Verizon FiOS 85/85
Firefox/Chrome
RAM gets confusing but it is very important, Video RAM is the fastest of all.
Self Built Custom
MSI 890FXA-GD70
1920 by 1080
Logitech G11
A smaller Page File uses less HDD/SSD space.
The "1.5x RAM size" recommendation dates back many years (probably pre-XP).
RAM was a lot more expensive in the past.
That said, my W2K8 server book also recommends "1.5x RAM size".
As a rule, W7 only uses a few hundred MB (on my PC).
Since I have mine set to 2048 MB minimum, it uses slighty more than that amount of space on my HDD.
n/a
ASUS M4A88T-M/USB3 (AM3)
NVIDIA GeForce GTX 660
Realtek?
Samsung S23B350
Cooler Master
Antec GX300 Tower
3x Antec TRICOOL 120mm Fans
Wired Optical
DSL
Pale Moon (64 bit)
2018-12-27 Upgraded HDDs
tgfyhre, what does resource monitor > memory look like immediately after boot? Lots of things loading or some special program specifically addressing the pagefile?
My trusty old HP laptop got w7 32bit 4mb, 450mb fixed pagefile, and always have lots of memory available under all normal\daily use conditions, even with the 1gb+ set as reserved, & it's a fast, good machine. See attach.
Dell \ Lenovo\ HP \ Toshiba
W7, W8.1
MSE, Malwarebytes
FF
Okay, well setting my pagefile to 1024 isn't working very well for me. I set it last night, and this morning I ran phpar (a multi-threaded par2 parity program) to create some parity backup for some files while I was surfing using Firefox, and several times Windows popped up a message that I was low on memory, and my browser became sluggish and unresponsive. I never got that message once before I switched my pagefile over to 1024. So I guess I'll just switch my pagefile back to where I had it initially (1.5x my RAM).
@4WD, I'll check my resource monitor the next time I reboot.
custom build
Asus P6T Deluxe v1
on board
Dell P2314H
Antec 1200
AZIO Prism
Logitech G700S
Verizon FiOS 85/85
Firefox/Chrome
A good rules of thumbs is to star using the same amount of real storage as paging... Then you can tune it depending on your particular usage...
Windows 7 Profesional x64
AMD Phenom II 965 X4 BE
ASUS M5A87
8GB - 4x2GB @ 1600 Mhz
ATI Radeon 6870 HD
On Board
Syncmaster BX2250
1080p
Internal Caviar Blue - 500GB | External WD MyBook - 3TB USB3 | External WD MyPassport - 320GB USB2
CoolMaster 600W
A very old and used Genius
6Mbps Cable
Kaspersky
Firefox as 1st Option
