You should upgrade or use an
alternative browser .
Solved Plz help, monitor randomly shuts off/system still on
yep that's the version i have, and no unfortunately its not
and the reason i didnt want to move the video card from the first slot is because some of the fan cords wont reach around it
Windows 7 Ultimate X64 AMD Phenom(tm) II X4 940 Processor 3.02GHZ Corsair Dual Channel TWINX 2048MB PC6400 DDR2... NVIDIA GeForce 9800 GTX/9800 GTX ( Now Radeon... OSWindows 7 Ultimate X64 CPUAMD Phenom(tm) II X4 940 Processor 3.02GHZ MotherboardMSI K9N2 Diamond Motherboard - NVIDIA nForce 780a SLI, Socke MemoryCorsair Dual Channel TWINX 2048MB PC6400 DDR2 x 4 (3.97) GB Graphics Card(s)NVIDIA GeForce 9800 GTX/9800 GTX ( Now Radeon HD 5750) Screen Resolution1920x1080 CaseCool Master
Take the side panel off and don't worry about the fans right now... let's get the major issue out of the way... then we'll worry about the minor issue of cable management.
If you have a room fan, you can just point it into the case while we're testing another pci-e slot.
7 Ultimate x64 i5-2500k 8GB G.Skill Ripjaws X F3-12800CL7D-8GBXH 1866... EVGA GTX 570 SC OS7 Ultimate x64 CPUi5-2500k MotherboardAsus P8P67 Pro Memory8GB G.Skill Ripjaws X F3-12800CL7D-8GBXH 1866MHz 8-9-8-24 Graphics Card(s)EVGA GTX 570 SC Sound CardX-Fi Titanium Fatality Monitor(s) DisplaysSamsung S27A550H 27" LED Screen Resolution1920x1080 Hard DrivesOCZ Vertex 3 120GB.
1TB Samsung F3.
2TB Samsung F4. PSUPC Power & Cooling Silencer 760 CaseLian Li Lancool K62 CoolingThermalright Venomous X Black/Scythe S-Flex/Shin-Etsu X23 KeyboardMS Natural Elite 4000 Ergonomic MouseLogitech G500 Internet Speed6MB/768 Other InfoLogitech Z-5500 505 watts.
D-Link DGL-4500.
Tripp-Lite Smart Pro 1500.
R.I.P. 7/09/2014
As long as the graphics card fan operates, you can do without the case fans long enought to test a new slot.
Windows 7 Ultimate X64 SP1 Intel i5-2550K, Differing ~4.4-4.8GHz No buil... 16GB G.Skill Sniper 1866MHz @ 2133MHz 2x8GB ASUS GTX650TIB-DC2OC-2GD5, (650TI Boost) Computer typePC/Desktop Computer Manufacturer/Model NumberHome Built Desktop By DataTech OSWindows 7 Ultimate X64 SP1 CPUIntel i5-2550K, Differing ~4.4-4.8GHz No built in GPU MotherboardASUS P8Z68-V PRO/GEN3 Memory16GB G.Skill Sniper 1866MHz @ 2133MHz 2x8GB Graphics Card(s)ASUS GTX650TIB-DC2OC-2GD5, (650TI Boost) Sound CardOnboard Realtek 5-1 Monitor(s) DisplaysSamsung P2570HD Screen Resolution1920x1080 Hard DrivesSamsung 840 Pro 256GB SSD for OS, 500GB Seagate Constellation (Enterprise drive) for Data PSUCorsair HX650W CaseInwin Dragon Rider CoolingHyper 212 EVO w/two Noctua fans, push-pull, @1300 RPM KeyboardE-Z Eyes, bright yellow keys with large characters Mousesteelseries SENSEI Laser Pro Gaming Internet Speed48-51Mbs Mbs down, 11 Mbs up Xfinity Cable AntivirusNorton Internet Security 2013 BrowserIE 10, Opera, Pale Moon if needed Other Info4 case fans, LG BluRay-RE, ASUS DVD-RW, Mr. Fusion power supply, 1.21 gigawatts.
after changing the slot, i played for an hour with no crashes. Unfortunately, i have to go to school so well see if it crashes after i get back, but this might have fixed it (its looking up at least)
1TB Samsung F3.
D-Link DGL-4500.
R.I.P. 7/09/2014
Hoping it holds for you.
Never mind, i guess that was just a lucky hour... it still crashes
R.I.P. 7/09/2014
Sorry about that. did you uninstall old drivers before updating to the new one?
no i just used the Nvedia auto update, but now that i have the panel off, i rly think its the video card, since the "fan noise"(when computer crashes) that i talked about earlier is the video card... i think im just gonna have to send it in
How attached are you to that card? It's pretty dated, so you would have to weigh the cost of repairing it against the cost of a new card.
Not that getting another GPU heatsink and fan assembly would be expensive, but it would still be pouring money into an outdated card... your best bet would be to just get a new card.
1TB Samsung F3.
D-Link DGL-4500.
it should be under warranty still, by the way would i be able to use " Galaxy NVIDIA GeForce 9500 GT 1GB PCI-E 2.0 SLI"
or what cards can i get my my motherboard? or any cards you would recomend that are afortable and compatible with my motherboard?
Yes, you can use a 9500GT, but why on earth would you? That's a downgrade from your current card, which is already old... the 9500 would be worse.
You can have your pick of any PCI-express card made.
"Affordable" is a relative term. What's your budget?
1TB Samsung F3.
D-Link DGL-4500.
R.I.P. 7/09/2014
That card or any PCI-e X16 card will work provide you have the room AND any needed power cables for it.
Do you guys stay up all night?
Some random thoughts...if the card was being over-worked, wouldn't the whole system shut down or BSOD? Check the games you play most often and see what the minimum hardware requirements are, sisnce LoL (?) plays.
Any card here would work, limited by your budget and power connectors. Fumz is correct, the 9500 is about 2 steps backwards.
Also consider the possibility that it could be the power supply.
Download and run this:
CPUID - System & hardware benchmark, monitoring, reporting
Let it run, play a game for just about 5-10 minutes, then exit, if it crashes do it again the same, see what temps you hit. Post this info back here, with a screenshot.
It could easily be a rail giving out on the psu, good to test this before you spend any money.
HP Win7 Pro x64 | Custom Win7 Pro x64 HP PhII X4 965 Black Ed. 3.4Ghz | PhII X6 110... 8GB DDR3 1333 OC Black Edition x2 HP XFX Radeon HD4890 1GB | AMD Radeon HD 6990 Computer Manufacturer/Model NumberHPE-112y Custom + Custom Build OSHP Win7 Pro x64 | Custom Win7 Pro x64 CPUHP PhII X4 965 Black Ed. 3.4Ghz | PhII X6 1100T 3.3/3.7 MotherboardOEM HP | ASUS Crosshair IV Extreme 890FX Memory8GB DDR3 1333 OC Black Edition x2 Graphics Card(s)HP XFX Radeon HD4890 1GB | AMD Radeon HD 6990 Sound CardRealtek 7.1 Digital HDMI x2 Monitor(s) DisplaysHP 20" 1680x1050 LCD | Samsung 23" 2ms 1920x1200 LED Screen Resolution1680x1050 + 1920x1200 & HDTV for Gaming/TV Hard Drives1TB WD "Green" 5,400 RPM SCSI W/ AMD RAID/Xpert
Custom 2x 128GB OCZ Enyo SSD PSUThermaltake Black Widow 850watt Modular x2 CaseHP HPE- 112y OEM Modded | Custom Xclio A380S CoolingHP Antec120mm | Custom Antec 360mm/250mm/200mm/120mm KeyboardHP G15 | G19 MouseG500 x2 Internet Speed15mb down, 2mb up Other Info2x DVD-RAM | 2x BD-ROM
R.I.P. 7/09/2014
Yup, works for me.
Actual shot of CPUID HW monitor.
This is a screen shot after 10 minutes
32.1 KB
R.I.P. 7/09/2014
Your graphics card is very hot! did you check you game specs?
31.5 KB
ya, its counter-strike its a game from like 2001, and practically any computer should be able to play it, but here the specs for it
Minimum: 1.7 GHz Processor, 512MB RAM, DirectX® 8.1 level Graphics Card (Requires support for SSE), Windows® 7 (32/64-bit)/Vista/XP, Mouse, Keyboard, Internet Connection
Recommended: Pentium 4 processor (3.0GHz, or better), 1GB RAM, DirectX® 9 level Graphics Card, Windows® 7 (32/64-bit)/Vista/XP, Mouse, Keyboard, Internet Connection
R.I.P. 7/09/2014
You might try the driver reinstall again, First uninstall you current driver, have the new one on your PC ready to install.
Use Revo Uninstaller .
