Power Option Sudden problem..
zealouszar
6:59 PM
Hello,
I am using Windows 7 Ultimate 32 bit on my HP 6910p Laptop. The power plan options were working absolutely fine, but suddenly it has started to act weird. When I used to select a power option For instance , when I click High Performance: The brightness used to be full (As I Configured this plan to have max screen brightness) and when I used to switch to Power Save: The brightness used to be lowest (As I configured this plan to have lowest screen brightness)
However, now, when I switch between the plans, nothing happens. For instance, if I click high performance, the brightness remains the same as clicking the power save plan. Also, If I choose High Performance power plan and lower its brightness, and then click on power save the brightness remains same as the high performance. So, Apparently, there is no change.
Can anyone suggest me what to do?
I have also Battery-Care software installed if that helps.
Thanks.
HP 6910p Laptop
Core 2 Duo 2.2Ghz
2 GB
Intel Integrated
HP M9077c
ASUSeK
6GB DDR2 6400
GeForce 8500/512MB
Realtek High Def Audio
HP w2408 LCD 24" widescreen
1920x1200
6 pack of Bud
MS wireless Inteli
MS wireless Inteli
