Power plan - do not keep settings!
paulobao
11:40 PM
I'm running Win7Pro 64bit in a Tecra R840 laptop. My power planning regarding LCD brightness is 40% if running on batery and 100% if plugged in.
The problem is that, for some reason, I can't keep these settings and Windows (?) change it to 40% on batery and plugged in. Example: I change settings to 100% if plugged in (and my laptop is plugged in). The brightnes is at 100%. Then I shut down and start with batery. Brightness is 40%. Everything ok until now...but if I plugged in again the brightness will stay at 40% and if I go to power options I can see that the plugged in option changed to 40%!!!!
Any help will be appreciated.
Regards,
paulo
Toshiba Tecra R840
Windows 7 Professional 64 bit
I7 2640M
8 GB
AMD Radeo HD 6450M
HD+ 14 inch
HDD 500GB 7200 rpm
Do you click Save Settings after changing them?
If you run HD Tune it will mess with power settings.
Windows 7 Ultimate X64 SP1
ASUS P8Z68-V PRO/GEN3
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
Norton Internet Security 2013
Yes I save it and I do not have HD tune :-(
Cheers,
paulo
Toshiba Tecra R840
I7 2640M
8 GB
AMD Radeo HD 6450M
HD+ 14 inch
HDD 500GB 7200 rpm
If you do the save power settings and reboot with it on outlet power the whole time, is it at 100%?
Just wondering if you are going to outlet power while it is still on, via battery, and at 40% setting, and that is causing it to lock 40% for both somehow.
Is that laptop running any brand specific software at bootup?
Run msconfig.exe from search box and go to the Startup tab for the list of items.
Self Built Custom
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was required!
MSI 890FXA-GD70
8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo nonOC max rec'd]
Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Frozr model
Realtek High Definition Audio (onboard mobo, ALC-889 chip)
2 WS LED Monitors: One LG One Viewsonic
1920 by 1080
SSD for OS: Samsung 840 Pro
SSD for VM and utilities: Adata SX900
7200 RPM SATA HDs for the rest: Hitachi and Seagate
Corsair TX850 - 850W max, in service since August 2010.
Thermaltake Armor A90
Thermaltake Spin Q CPU Cooler, in service since August 2010
Logitech G11
Logitech M310 Wireless
100 Megabit broadband supposedly upgraded from 50 (Cable)
Bitdefender Internet Security 2014 suite
Pale Moon 64-bit main, also IceDragon, Opera, and Maxthon.
CompTIA A+ certified (220-800 series) in July 2013.
Yes and no! If I reboot with the outlet power the brightness will remain at 100% sometimes...! Sometimes it will be at 40% brightness.
Yes it runs flashcards from toshiba.
cheers,
paulo
Toshiba Tecra R840
I7 2640M
8 GB
AMD Radeo HD 6450M
HD+ 14 inch
HDD 500GB 7200 rpm
