Problem With 5.1 Surround Sound Output
Joe Ciaravino
1:17 AM
Windows 7 64 bit OS with Realtek integrated sound on motherboard. If I go to the Realtek application on my computer and test the speaker output, I get a correct test sound from all front, rear, center, and subwoofer speakers. However, when I play music with WM Player, iTunes, or any other application, I only get stereo sound (front pair speakers work only).
custom build
Win 7 64 bit Home Premium
AMD A6 6400K
Gigabyte
8 bg
SSD plus HDD
In the Realtek app there should be a box on the configuration page that you should be able to tick.
The box is "Speaker Fill" and when you hover over it: Speaker expansion makes stereo sound hearable to multi-channel speakers!
This is how it looks for me:
Cheers, Boris :)
Custom build
Windows 7 Home Premium
i5-3570k
ASUS Sabertooth z77
16 GB DDR3 G Skill Sniper
GIGABYTE GeForce GTX 970 GV-N970WF3OC-4GD
ASUS ROG PG278Q
2560x1440@60Hz/120Hz/144Hz
56GB KINGSTON SVP200S37A60G
512GB Crucial MX100
1863GB Seagate ST2000DM001-1CH164
2795GB Seagate ST3000DM001-9YN166
Corsair GS800
Storm Trooper Stryker White
Logitech G910 Orion Spark
Logitech G502
Firefox/Chrome
Logitech G633
Logitech Mouse Matt
I know this sounds like a simple question and no disrespect, but is your source multi-channel, or stereo?
CD-audio is only 2-channel stereo, so if that's the the original source for your music then it would also be 2-channel stereo. It's understandable that 2-channel music would be played back through your two L/R fronts.
On the other hand, genuine multi-channel sound (e.g. from playing a BluRay/DVD, or from a media file with multi-channel audio) would of course be heard from all your speakers.
Home-built, two systems (1) and (2)
i5-3350p 3.1Ghz/6MB-cache (1); E8400 3.0Ghz/6MB-cache (2)
ASUS P8Z77-V Pro (1); ASUS P5Q3 (2)
8GB PC3-12800 DDR3 (1); 4GB PC3-10600 DDR3 (2)
ATI HD7750 (1), (see TV cards); ATI R7 250 (2)
Realtek ALC892 HD Audio (1); Realtek ALC1200 HD Audio (2)
Eizo HD2441W LCD, Eizo S2433W (1); Eizo 24" S2433W (2)
1920x1200, 1920x1200 (1); 1920x1200 (2)
(1) 1TB SATA-II (7200RPM), 2x2TB SATA-III (7200RPM), 250GB SATA-III (10000RPM) for OS; 2x2TB external USB 3.0
(2) 320GB SATA-II (7200RPM), 750GB SATA-II (7200RPM), 150GB SATA-II (10000RPM) for OS; 2TB external USB 3.0
Nesteq ECS-6001 600W (1); Nesteq ECS-5001 500W (2)
Acousti-Case 360 (1) and (2)
Noctua NH-U12P SE2 for CPU, 2x120mm case fans (1) and (2)
IBM PS/2 (1) and (2)
Logitech MX Revolution wireless (1); Microsoft wired (2)
100mbps down / 10mbps up
Microsoft Security Essentials; Malwarebyte Anti-Malware Pro
Ceton InfiniTV 4-tuner cablecard-enabled TV card as well as Hauppauge HVR-2250 OTA/ATSC 2-tuner TV card in (1), running under Win7 WMC
Cheers, Boris :)
Yes that works. Thank you.
custom build
AMD A6 6400K
Gigabyte
8 bg
SSD plus HDD
You have analyzed things somewhat more. When I playback some older recordings, possibly if not probably recorded in monaural, these only emit sound from the "front" speaker pair. When I now play audio (probably) recorded/reproduced in stereo, the sound emits from ALL speakers.
In any event, I am now satisfied with the results, despite the fact that I don't fully understand the process used to simulate 5.1 channel audio. I am grateful for both of your comments as well as your helpful remedies, Animal and DSPerber.
In the final analysis, my system now emits sound from all 6 speakers when playing stereo recordings..............simulated "matrix" sound, which is what I want. When playing older, monaural recordings, the sound emanates from the front speakers only. That is perfectly acceptable. When "true" surround sound is played back, I assume that it is truly reproduced from all 6 speakers, although I cannot discern whether it is "fidelity" reproduction or not.
custom build
AMD A6 6400K
Gigabyte
8 bg
SSD plus HDD
Hey nice to hear you got it fixed, and am happy to help!
Cheers, Boris :)
Custom build
i5-3570k
ASUS Sabertooth z77
ASUS ROG PG278Q
512GB Crucial MX100
Corsair GS800
Logitech G502
Firefox/Chrome
Logitech G633
Logitech Mouse Matt
there's only four ways to go about it:
1. you are simply copying & pasting the front left to the rear left - the front right to the rear right.
2. you are analzying the audio of stereo that is capable of using virtual speakers & then every time the virtual speaker gets close to either the rear left or rear right, instead of asking all the timing of the speaker & room to do the virtual speaker, you instead simply play the audio from the rear speaker.
3. you could also use the rear speakers to pull & drag on the soundwaves from the front speakers to enhance or strengthen the virtual speakers.
4. using either number 2 or 3, you could add environment effects (including re-mapping of the speaker location).
ever since consumers have been able to buy speaker systems with rear speakers, they've taken half of the phase away from the front speakers and used it for the rear speakers (thus preventing the front speakers from being able to do it while in 'surround' mode - unless those channels are discrete).
i can hear audio from behind me using two front speakers, simply depends on whether the audio file has such an fx in it or not.
i haven't played with all of the different virtual surround modes in existence, but i also know the ones i have played with don't really do 2, 3, or 4.
i also haven't heard anybody talking about systems being able to do it.
seems the headphone industry has been the only subject that gets any attention about it.
here's an audio file that plays audio from behind: https://youtu.be/fSSLQf95-Nc
custom
windows 7 home premium 64bit
core2quad q6600 @ stock speed
xfx 680i lt
4gb ddr2
gtx285
virtual audio cable/realtek hd
ssd
seasonic 750w
antec
ergonomic 4000
logitech g5 (orange version)
10mbit down / 2 mbit up
www.facebook.com/bobby.rankin.7
