Problem with computer going into max CPU usage
e2cmole
12:19 AM
Just moved, now using Hughesnet and a Cisco linksys E#A4500 router, desktop hard wired into router port (compared to previous FIOS, also hardwired in).
Since setting up in the new location, when the computer goes into sleep or hibernation, it doesn't want to come out. It either stays asleep, or it comes up and the CPU goes into 100% usage, freezing everything else. Only way out is to restart ands when I restart, it works fine. MS Security essentials says no viruses, SpyBot finds no malware, and Windows malicious software tool finds nothing bad.
Any ideas on eliminating this problem?
HP-Compaq
Windows 7 Home Premium 64 bit
Athlon II 170u
standard with computer
4GB
360GB
Microsoft Security Essentials & Spybot
google Chrome
Sounds like an infection despite your findings.
If possible when the CPU is at max. Hit Control, Alt, Delete. Just one time, give the PC time to respond. Select Task Manager. Again, wait for a response. Select Processes tab. Under the CPU heading, look for the process which is maxing out the CPU. Now, Right-Click on the Image Name and select End Process. If successful, Let us know the name of the process.
You can also try this. http://www.sevenforums.com/tutorial...ation-conflicts-performing-clean-startup.html
Also, try disconnecting any attached Hardware. Internet Devices, Speakers, etc. Restart the PC, several times, with only the Monitor, Keyboard, and Mouse connected. Any difference?
Check Device Manager for any problems there.
John
My Computers
    HP Pavilion 6751c
    Win7, Win10, Win11
    100 Mbps
    Norton 360
    IE 11
    HP ENVY 750-514 & Dell XPS 8960
    Win7, Win10, Win11
    Norton 360
Already tried the task manager, no apps listed and no CPU usage listed on the processes tab except for task manager. Occasional blips up from 0 usage for tea timer, part of spybot, but that's normal. The only place Task Manager shows it is on the performance tab. I agree it sounds like an infection, I just can't find an infection
I''ll try the other two. The only peripheral that is new is the router and hughesnet modem. There are two other computer are running on the router without this problem, so that is doubtful as a cause
Don't know what I should look for in device manager.
HP-Compaq
Athlon II 170u
4GB
360GB
google Chrome
Device Manager would show problems with drivers. Once there click on View tab, select Show hidden Devices.
Look for one of three signs: red ex, yellow question mark, yellow exclamation mark.
Post back if you find any issues there.
You might consider asking a Moderator to move your post into the System Security Forum, there one of our trained members in Virus, Malware removal can assist you further. They would most likely ask you to download Farbar Recovery Scan Tool. Have you run a system scan and post scan log results. They will analyze log entries to determine whether or not your system is infected.
Personally, I feel this would be a next step in troubleshooting your system.
However, perhaps one of our other members will see your post, and offer other suggestions.
John
My Computers
    HP Pavilion 6751c
    Win7, Win10, Win11
    100 Mbps
    Norton 360
    IE 11
    Win7, Win10, Win11
    Norton 360
I'll try that, thanks
HP-Compaq
Athlon II 170u
4GB
360GB
google Chrome
I discovered the poblem. Spybot was going crazy. I uninstalled spybot aqnd the problem went away....
downloaded the latest spybot and ran it overnight, came back in the morning, had the sme problem, spybot was running and using the entire cpu, which is normal, btu it turned itself on and I couldn't tun it off. Never had the problem before and this is a clean copy, so i'm assuming something something in the OS changed with one of the security updates. Will also talk to safer-networking. spybot finds a lot of bad stuff that security essentials doesn't, so I'd like to keep using it, but only if I can figure out how to fix the problem
HP-Compaq
Athlon II 170u
4GB
360GB
google Chrome
I would stop using spybot all together. It's a very buggy program. It used to be good back in the old days, but it causes a lot of problems now.
Spybot - Search & Destroy 2.0 Review & Rating | PCMag.com A little old, but gets the point across. I have tested it on multiple PCS and virtual machines and find it causes a lot of issues.
Side note: I used to be a very active user of spybot 4 years ago. I was also very active on their forum. But the program since the major update is just horrible.
But you decide for yourself.
Windows 10 Pro
Motherboard Built in
Wired Dell keyboard
Wireless Logitech mouse
250mb down, 30mb up
Panda Cloud Antivirus
Chrome-ish x64
The only problem with that idea Andrew is that Spybot catches a lot of adware that Microsoft Security Essentials doesn't. And then thee's the fact that Spybot ver 1 is working just fine on my laptop, and that is what was on my desktop when this started. It looks to my inexpert mind like an incompatability issue or a corrupted file in the OS rather than buggy software.
HP-Compaq
Athlon II 170u
4GB
360GB
google Chrome
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
8.00 GB DDR3 1600Mhz
MSI Gaming X GTX 1070
Realtek High Definition
Dell S23O9W, HP L1710
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
MSI DS100 Interceptor
50 down and 5 up
Chrome, IE 11
Logitech X-620 Speakers
