Problem with LAN and LAN internet sharing.
The next thing to try is set the client pc with the IP addressing that i provided and go to your browser and type the following IP address in.
216.236.51.99
If this doesnt or does work then on your client pc goto your hosts file.
C:\windows\system32\drivers\etc\hosts
open with notepad
below the 127.0.0.1 i want you to put 192.168.137.1
below the local hosts i want you to type the name of your HOSTpc
now try again.
For accessing you files on the HOST make sure they are enabled to share accordingly.
CustomBuild001
7 ultimate x64
Intel core i7 2600K
ASUS P8Z68-V PRO
Vengeance™ — 16GB Triple Channel DDR3 PC16000
GeForce GTX 560 Ti
HannsG 22" widescreen (HDMI)
Samsung 1TB x2(RAID1) Deskstar 160G, Buffalo ExHD 500GB
Corsair 850HX
Antec Three Hundred Gaming Tower Case
CPU Freezer 7 Pro Rev. 2...ANTEC 3phase cooling, 2 intake.
microsoft intellitype 6000 v3.0
microsoft sidewinder
50Mb
64GB SSD in pipeline for Intel Smart Response Technology.
I tried.Didn't help.
I tried to put some public DNS like 4.2.2.2 or 8.8.8.8 in alternate DNS server and then internet start working.
But as always it stops in a couple of minutes,didn't work for about an hour,then again worked ten minutes...and so on and so on in circle...
Files are shared properly.
As i said with previous pc that public DNS saved me,but now nothing :(
Windows 7 Professional x32
The next thing i can advise you is to set the client pc to DHCP, Then switch off the client pc.
Goto your HOSTpc, Disable the ICS and then enable the ICS.
Goto your sharing settings in the HOSTpc and make sure they are all shared.
Then switch you client pc on and test connectivity.
Otherwise have a look here for some troubleshooting.
Using ICS (Internet Connection Sharing)
Remember that you will still have to use the 192.168.137.x IP addressing for win7.
Also consider getting one of these for simplicity.
NETGEAR ProSafe FS105 10/100 Desktop Switch Switch - EN, Fast EN - English / United Kingdom
CustomBuild001
7 ultimate x64
Intel core i7 2600K
ASUS P8Z68-V PRO
GeForce GTX 560 Ti
Corsair 850HX
50Mb
I did all of that my friend,nothing changed.
Last night with previous CLIENT pc settings all like u said + alternate DNS server 8.8.8.8 worked for a couple of hours.This morning stopped again.
Now internet works again but i don't know for how long...It is pretty annoying.
