Realtek HD Audio Very Very Low Volume - Mb: ASRock Z77Extreme3
Hangsta
12:26 AM
Hello,
I'm having an issue with my audio, the problem is that my volume is extremely low even with maxed out settings in realtek audio manager and speakers turned all the way up. I have tried installing and reinstalling drivers from MB drivers and directly from Realtek to no avail.
I've searched on endlessly on a few forums and could not find a fix for my problem. Is there anything else I could try? I've tried changing to 5.1/different bitrates/fresh Win7 install/different version drivers. Im exhausted :(
Might have to resort to change my MB maybe?
Windows 7 Professional x64I5 347016GBPNY GTX 660
I5 3470
ASRock Z77 Extreeme3
16GB
PNY GTX 660
Sandisk 120gb ssd
Seagate 1TB
Corsair HX 650
First thing is the sound driver. You should be using the ASRock supplied RealTek sound driver. What do you show for sound devices in the Device Manager? You should have HDMI Audio (Video card) and the RealTek sound driver. If you have something else such as the generic Windows installed HD Audio Codec that is one of your problems.
I assume you are using "powered" speakers (ones with their own power amplifier). If not, that is most likely the problem as powered speakers are required. Plug a headset into the GREEN speaker jack on the rear and see if you get adequate sound, if the headset works OK then the problem is in your speaker system and not the PC.
If the headphone sound is also low, its back to the PC.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I have 3 installed in device manager. Should I uninstall the intel display audio and hd audio device?
Sound output is the same with headphones and speakers.
I5 3470
16GB
PNY GTX 660
Sandisk 120gb ssd
Seagate 1TB
Corsair HX 650
Uninstall the High Definition Audio Device.
Restart the PC and then check the Sound Panel/Playback Section to make sure your "Speakers" are set as the default audio playback device.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I uninstalled the High Definition Audio Device but it reinstalled right back when I got into Windows and yes the Speakers are set as the default audio playback device.
I5 3470
16GB
PNY GTX 660
Sandisk 120gb ssd
Seagate 1TB
Corsair HX 650
There is some other device causing the HD Audio Codec to install.
Does the PNY GTX 660 have an HDMI port? If it does, there should be a driver for that and it should be listed in the Device Manager. If no driver (or incorrect) driver was installed that may be why the HD Audio Codec is installing.
The Intel Display Audio is for the built in video/HDMI in the i5 CPU chip. If you are not using the Video in the i5, that should have been disabled in the BIOS. I have a second PC with an i5 and since I'm using a separate video card (GTS450) the i5 has been automatically disabled by the BIOS and does not show up in the Device Manager.
I know this is not directly addressing your low volume problem. But, got to get all the other things straightened out first. Then they do not become a potential issue.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Yes the PNY GTX 660 does have an HDMI port. So, I took out the Graphics card to get rid of the HD audio device. (I'm not going to be using the gtx 660) So now I only have 2 devices under sound. Intel display audio and realtek.
Also a note;
The output sounds like its only coming from the right speaker. My left speaker and subwoofer are not getting any signals. I'm using the green line out jack. This just recently happened I haven't installed any drivers lately, only windows security updates.
I5 3470
16GB
PNY GTX 660
Sandisk 120gb ssd
Seagate 1TB
Corsair HX 650
Are you fully inserting the plug? If it were only partially inserted you would only get one channel.
My RealTek HD Audio Manager has a Left/Right control. If yours has this make sure its centered.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Windows 10Intel Core i5 3570K16GB 1600Mhz G.SkillGigabyte GTX 970 G1-Gaming
Windows 10
Intel Core i5 3570K
Asus P8Z77V-PRO
Seasonic 1000W Platinum
Fractal Design Define R4
Noctua NH-D14
Yes its fully inserted and centered. I'm pretty sure its not the speakers because when I plug it into my ipod its fine.
Yes I checked disabled all sound effects.
I5 3470
16GB
PNY GTX 660
Sandisk 120gb ssd
Seagate 1TB
Corsair HX 650
With what has been done, I would suspect the motherboard. If its still in warranty contact ASRock. I had initial problems with a new ASRock Z77 Professional (Fatal1ty) motherboard (memory slots) and after back and forth with their support they finally agreed to replace it.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Ok thanks! I think I will have to give them a call.
I5 3470
16GB
PNY GTX 660
Sandisk 120gb ssd
Seagate 1TB
Corsair HX 650
