Solved Rear Fan Direction Help!
Thanks for the help Ciara and Linnemeyerhere :)
Windows 10 Pro
Core i5 9600K
ASUS ROG Strix Z390-F Gaming
Corsair Vengeance Pro 2x 8GB (16GB) 3200MHz DDR4
MSI GTX 1070 Gaming X 8GB
ASRock A-Style Purity Sound
ASUS VX239H IPS
XPG SPECTRIX S40G 2566GB M.2 NVMe | Patriot P210 512GB SSD | Seagate BarraCuda 4TB 5400RPM
Thermaltake Smart 600w RGB 80Plus
NZXT H500 with 3x Corsair HD120 RGB w/Node Pro
Cryorig H7
Corsair K70 RapidFire RGB (Cherry MX Speed)
Logitech G402 Hyperion Fury
20MB Cable Broadband
Corsair MM300 Extended Anti-Fray Mouse Pad | Edifier C2 2.1ch Sound System | XBOX One S Controller | XBOX 360 Wireless Controller for Windows | APC SUA1000i Smart-UPS | PS4 Slim 500GB [Region 1 - USA]
I'd go for a neutral airflow. I have two 90mm Vantec fans, one in the front bottom and one in the top rear below the power supply in my case. One brings cool air in and the other takes it right out. Best setup ever! If you don't know what the airflow ratings are for your two fans, I'd go with a negative airflow in your case. Take the two fans and run them together and see (or feel :)) which one has more suction/airflow. Then, take that fan and place it in the back.
But make sure that if it's your 120mm fan, it can fit in the back.
ASUS
AMD Athlon 240 II @ 2.8-4.004 ghz
M4A78LT-M LE
SuperTalent 4gb DDR3
ATI Radeon 3000HD
1440*900
Re-modded Dell Dimension 4550
Vantec 92mm Tornado x2
It looks pretty.
