Recent BSOD, "Drive_Power_State_Failure," Need Help!
Timia27
4:38 AM
Hi. My computer has been crashing very often recently with the BSOD saying, "Driver_Power_State_Failure." It is a refurbished computer form Windows XP, running Windows 7 with an Intel Prentium D processor. I have tried to fix it but nothing I have tried worked. If anyone knows how to fix this, please let me know. Thanks!
Samsung
Windows 7 Home Premium 32bit
Trend Micro
Welcome to the forum.
If you have any device connected to the USB ports, safely remove and unplug them from the system for the time being.
Start Menu\Programs\Advanced SystemCare 7	Public:Start Menu\Programs\Advanced SystemCare 7	Public
This software is a known cause of BSOD's. The windows 7 operating system does not require these registry cleaning software. They often tune-down rather than tune-up and can wreck the OS beyond repair. Microsoft have improved Windows 7 significantly and it is much better at organising and optimising itself than its predecessors. Check this, this and this thread for evidence. If you feel the need to use a registry cleaning or optimisation software, most of us recommend the use of CCleaner - PC Optimization and Cleaning - Free Download but make sure you back up the registry before making letting ccleaner delete anything. 10 Tips on How to Properly Maintain Your Computer
Start Menu\Programs\Trend Micro Titanium Internet Security	DeMember-PC\DeMember:Start Menu\Programs\Trend Micro Titanium Internet Security	DeMember-PC\DeMember
Start Menu\Programs\Trend Micro Titanium Internet Security\More Tools and Help	DeMember-PC\DeMember:Start Menu\Programs\Trend Micro Titanium Internet Security\More Tools and Help	DeMember-PC\DeMember
Trend micro can be a cause of BSOD. Please remove it for testing purpose. Use Microsoft Security Essentials.
Recommended from a strict BSOD perspective, compatibility & stability compared to other security software:
Microsoft Security Essentials - Free Antivirus for Windows
Malwarebytes - Free
http://www.sevenforums.com/system-security/206705-good-free-system-security-combination.html
Please update these older drivers. Links are included to assist in looking up the source of the drivers. If unable to find an update, please remove (un-install) the program responsible for that driver. DO NOT manually delete/rename the driver as it may make the system unbootable!:-
mdc8021x.sys Mon Jun 2 00:09:41 2003 (3EDA4165)
IEEE 802.1X Protocol Driver - a part of AEGIS Client 2.2 software by Meetinghouse Data Communications (acquired by Cisco Systems)
Driver Reference Table - mdc8021x.sys
mausbmp.sys Wed Jul 9 22:42:57 2008 (4874EA91)
mausbmp.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
adfs.SYS Thu Aug 14 20:57:15 2008 (48A447CB)
Adobe File System Driver
Driver Reference Table - adfs.SYS
e1e6032.sys Wed Mar 25 00:16:11 2009 (49C9236B)
Intel PRO/1000 Adapter NDIS 6 deserialized driver
Driver Reference Table - e1e6032.sys
athr.sys Wed Jun 10 00:04:52 2009 (4A2EA444)
Atheros Extensible Wireless LAN driver for CB42/CB43/MB42/MB43 Network Adapter - D-Link AirPlus DWL-G520 Wireless PCI Adapter(rev.B) discontinued 2008
Driver Reference Table - athr.sys
Perform a clean install of a driver following: How to Clean Left Over Driver Files with Driver Sweeper
Run a System file check (SFC): http://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
Scan with Kaspersky TDSSKiller:Anti-rootkit utility TDSSKiller
ESET online scanner: Free Online Virus Scanner | ESET
Run Disk Check on your Hard Drive(s): http://www.sevenforums.com/tutorials/433-disk-check.html
Check for heating issues using Speccy or HWmonitor
Upload a screen shot: http://www.sevenforums.com/tutorials/9733-screenshots-files-upload-post-seven-forums.html
Keep us posted.
Self assembled
Windows 10 Home 64Bit
Intel Core i5 10400 @ 2.90GHz
Intel Corporation DG41WV (PROCESSOR)
8.00GB Single-Channel Unknown @ 1329MHz (16-20-20-38)
DELL E170S
1280x1024 pixels
931GB TOSHIBA DT01ACA100 (SATA)
238GB TEAM TM8PS7256G (SATA SSD)
Nothing Fancy
Fans
A4 Tech Co LTD
A4 Tech Co Ltd/Logitech
25 Mbps
Thank You
Thank you for helping me with this now I will just have to see if the problem arises again. Just a few questions. Are the temperatures of the motherboard (40c) and storage (48c) OK? If not is there a way to fix that? Also, do you know of any way to restore the registry, if parts of it may have gotten messed up? Thank again!
Samsung
Trend Micro
That sounds okay to me.
That's alright. Have you run the SFC command?
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
Not yet I will try that ASAP.
Samsung
Trend Micro
New Problem
Hi again! The problem seemed to be resolved, but then I started to get blue screens again. Here are the latest files. Thanks again.
Samsung
Trend Micro
Sorry for the late reply but have you completed all the steps on my first post?
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
I am working on it right now😀
Samsung
Trend Micro
