Selecting parts for new build
sergiogarcia9
︻┳テ=一
10:43 AM
Hi Guys
I am currently deciding which parts to get for my new build
I already have a case (will most likely be replaced tho), and will also have 550w PSU and a 500GB HDD soon
Therefore, i just need CPU, Motherboard, Ram, and Graphics Card
So far this is what i have found:
Motherboard: MBAM3 AMD-870 Gigabyte GA-870A
Gigabyte GA-870A-UD3 Socket AM3 Motherboard
CPU: Phenom II X6 1055T/AM3 2.8GHz 9MB 125W
Buy the AMD Phenom II 1055T Six Core Processor at TigerDirect.ca
Ram: HyperX DDR3 1600MHz 4GB CL9 DIMM (Kit of 2)
Kingston Technology Company - HyperX DDR3 -
Graphics Card:
GTS250 1GB DDR3 Green version VGA, DVI,HDCP,
Palit- GTS 250 Green 1GB(1024MB)
These parts will be bought over a total time of about 5-8 months (as i need the extra cash for it)
Is my parts still going to good in that time? And are they good to use together? Also, are the 550w PSU too small or would it work fine?
All suggestions are welcome
SG
Your PSU should be fine as long as you don't plan on hooking up 10 monitors and many other power hungry additions.
Make sure the RAM you get is AMD certified, have seen a lot of problems when trying to use Intel RAM on a AMD MOBO.
Check the MOBO approved RAM list from their website.
The Gigabyte motherboard specs look good.
The rest looks good, as well.
Looks to be as future proof as you can be, check again before you buy.
76~2.0
Intel Core i5-3570K 4.6GHz
Gigabyte GA-Z77X UD3H, f18
Onboard VIA VT2021
22" LCD Dell
Samsung 840Pro 128GB SSD,
Corsair HX650W
Cooler Master Storm Scout
Logitech Wave
CM Sentinel
Dismal
Opera Next
Desktop: eSATA ports,
External WD USB 500GB
I tried the 1333MHz HyperX RAM by Kingston in my Alienware M17x on recommendation from quite a few folks on the Alienware Forum and my M17x and it did not get along so I returned it. Like Dave76 said I'd see what AMD and Gigabyte shows as tested compatible RAM for the mobo and CPU, I'd also see what the Overclocking Guru's have to say as well if OC'ing is on your radar.
DELL XPS Studio 435T
Vista 64 Ultimate, Windows 7 64 Ultimate, Ubuntu 9.10
i7 975 3.3 GHz Extreme (Factory OC'd to 3.6 GHz)
DELL provided
18 Gb Tri-Channel 1066
ATI 5970 2048 Mb
X-Fi Extreme Gamer
Vizio 37" HD-TV
1.5 Tb HDD
1.5 Tb HDD
2.0 Tb Network Drive
512 Gb Crucial SSD
DELL Provided 475 watts
DELL
3 fans
Logitech Performance K350 Wireless
Logitech Performance MX Wireless
3 Mb up 750 Kb down
Bamboo Fun Tablet, Belkin N+ Wireless router, Pioneer Dolby System Wireless Headphones, Bose 5.1 Dolby Surround Sound System, LifeCam VX 3000 Webcam, Blu-Ray/Hi Def DVD +RW combo and Blu-ray +RW,l 15 in 1 media card reader, Logitech Rumblepad 2, Hauppauge 2250 DTV Tuner with MS Media Center Remote
Laptop:Alienware M17x, Q9100 CPU, 8Gb RAM, 1920x1200 WUXGA LCD driven by 4870's in CrossFireX, Bl
Hello Capt. Looking good. That MB and CPU combo should be great. The Ram is what I have, and there are 3 kits on the approved list:
Specs
Click on memory support list on right sidebar.
The video card is good too, do you plan to game?
A Guy
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
ANTEC Three Hundred Illusion
85 + Mbps
Vivaldi
I only plan to hook up max. 2 Monitors ;)
I will have a look at the RAM, thanks :)
I am most likely not going to overclock. Six cores at 2.8ghz is more than enough for my needs :)
Specs
A Guy
That list is a bit long to read lol
Also, i plan to do light gaming. Things like Need For Speed, some other race games, GTA, Just Cause 2, nothing really special
I also would like a card which is good at 3D rendering, and can use that new cool app from Nvidia. Will this card be able to do that?
Hi Guys
Graphics Card:
SG
What about HDD? Are you gonna have the plain old one or a SSH?
Toshiba
Celeron
I will Fill in my Specs soon
Hi Guys
Graphics Card:
SG
I plan to use that 500gb, along with the 750gb HDD i have in my current machine ;) (current machine will still have a 500gb HDD after tho)
I might add an SSD, but it really depends on if the prices drops ;)
Hi Guys
Graphics Card:
SG
Oops Typo. Lol. Hopefully those SSD's do come down because I wouldn't mind one.
Toshiba
Celeron
What make and model Power supply.
This is probably the most critical component of any build and it is constantly ignored.
Self Built Custom Computer.
i7-4770K
Asus Z87 Sabertooth
16Gig DDR3-2400
Gigabyte GT740
Onboard
Benq 27" - Dell 23' - Benq 22"
Samsung 840 Pro 128g SSD
1xWestern Digital Caviar Green 1tb
2xWestern Digital Caviar Green 2 tb
Seasonic 760 watt Platinum
Coolermaster Haf - X
Noctua NH-C12P CPU Cooler
Logitech illuminated keyboard
Logitech Perfomance MX
Cable = speeds to 20Mbps downsteam and 512kbps upsteam
Avast Internet Security
I don't know yet. I am having it shipped from a friend in Germany and it should be here maybe the last day of this week or next week ;) I will post what brand and model it is when i get it :)
You only get to choose some parts Sergio? Not case or PSU? :)
A Guy
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
85 + Mbps
Vivaldi
A Guy
I'm getting the PSU for free, so i counted on using that to keep the costs a bit down ;)
The case i already have. A cheap one though, so i am considering getting another case.
Can you recommend any?
A Guy
Personally, I use the Antec 300. I think people tend to like the Haf 932
HAF 932
or their new one looks good
Haf X
Sure others will have suggestions :)
A Guy
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
85 + Mbps
Vivaldi
A Guy
HAF 932
Haf X
A Guy
Their new one looks extremely good :D But i cant find it in any danish online shop :(
But i've had a look at their HAF 922 instead
I really like it and it has some nice features and isn't too expensive. I might get it...
A couple things. I don't see an OS. Understand you cannot use a current copy of Windows if it came with another computer UNLESS it is a "full retail" version and you uninstall it from the other computer. To clarify, if you have an OEM copy of Windows, that is licensed to the hardware it was purchased for and therefore, you CANNOT transfer it to another computer. You MUST buy a new license for the new computer. Full retail versions are typically sold in boxes at retail stores. I have NEVER seen a full retail version sold with a factory made (Dell, HP, Gateway, Sony, Acer, etc.) computer.
I did not see any optical devices.
You said you will be buying these components over the next 5 - 8 months. With the exception of the case, and perhaps opticals, I think that would be a mistake. Instead of buying over a stretch of time, you should save your money until you can buy all at once. Otherwise, there's the risk your motherboard, for example, goes obsolete before you ever get a chance to turn it on. Certainly, a new revision could come out, or a different CPU that might work better for you. Also, many retailers offer "bundles" where you can save a few dollars buying.
I think 4Gb for that CPU is a mismatch - ESPECIALLY if going with 64-bit Windows and I see no reason anyone buying/building a new computer should not go 64-bit. 32-bit is history. I would fully populate your board with 4 x 2Gb not only to better match the CPU, but also so you don't have to worry about RAM compatibility issues down the road should you decide to upgrade later. Because certainly, you will not be able to find the exact same RAM.
I like Antec cases!!!! Sure, they are heavy and not the best looking, but heavy steel is more sturdy and that is important. Even the best aluminum cases can flex when moved (for monthly inspections and cleaning) and that can cause microfractures at the motherboard mounting points. Not good. As for looks, fancy facades go out of style and flashing lights do nothing for performance, consume power, add some heat, and do nothing for performance (worth repeating). And besides, I tend to watch my monitors, not the case. The case should sit quietly and discretely out of the way, protecting the components inside from knocks and heat.
I will NEVER buy a case again that does not have an easily removable, washable air filter. Period.
I like and use almost exclusively Gigabyte boards so IMO, that's a good choice. However, I like Intel CPUs but AMD makes excellent CPUs too.
Finally (if that's not enough ;)), your PSU should ALWAYS be the last thing you decide on. I agree completely with kodi - the PSU is the most critical component and is typically chosen as an afterthought, or as a place to save some money. I like to use the analogy of buying a new dream car. You wouldn't put off-brand generic gas from the corner tobacco/liquor/convenience store in your new Porsche would you? Well you might, but would you expect it to run at peak performance? A car engine can miss a beat and keep on running but not so for digital electronics.
So once you have selected all your components, then, and only then should you select your PSU. Here's my canned text on sizing and selecting a good PSU.
Use the eXtreme PSU Calculator Lite to determine your minimum power supply unit (PSU) requirements. Plug in all the hardware you think you might have in 2 or 3 years (extra drives, bigger or 2nd video card, more RAM, etc.). Be sure to read and heed the notes at the bottom of the page. I recommend setting Capacitor Aging to 30%, and if you participate in distributive computing projects (e.g. BOINC or Folding@Home) or extreme 3D animated gaming, I recommend setting both TDP and system load to 100%. These steps ensure the supply has adequate head room for stress free (and perhaps quieter) operation, and future hardware demands. Research your video card and pay particular attention to the power supply requirements for your card listed on your video card maker's website. If not listed, check a comparable card (same graphics engine and RAM) from a different maker. The key specifications, in order of importance are:
  1. Current (amperage or amps) on the +12V rail,
  2. Efficiency,
  3. Total wattage.
Don’t try to save a few dollars by getting a cheap supply! Digital electronics, including CPUs, RAM, and today's advanced graphics cards, need clean, stable power. A good, well chosen supply will provide years of service and upgrade wiggle room. Look for power supply brands listed under the "Good" column of PC Mechanic's PSU Reference List. Note that some case retailers “toss in” a generic or inadequate PSU just to make the case sale. Be prepared to “toss out” that supply for a good one with sufficient power. You can save the other for testing fans.
Most PSUs have an efficiency rating of around 70%. This means for every 100 watts of power a PSU draws from the wall, only 70 watts is delivered to the motherboard, with the rest wasted in the form of heat. The best supplies are 85 to 90% efficient, and as expected, cost more. I strongly recommend you pick a quality supply with an efficiency rating equal to or greater than 80%. Look for 80 Plus - EnergyStar Compliant labels.
Too big of a PSU hurts nothing but your budget. Your computer will draw from the PSU only what it needs, not what the PSU is capable of delivering. If a computer needs 300 watts it will draw 300 watts regardless if the PSU is a 350W, 650W, or 1000W PSU. In turn, the PSU, regardless its size will draw from the wall only what it needs to support the computer. In this example, it will draw 300 watts, plus another 45 – 90 watts, depending on the PSU’s inefficiency.
As noted, the eXtreme Calculator determines the minimum requirements. If the calculator (with the changes I suggested) recommends a 400 watt minimum, a quality 400W supply will serve you just fine. But a quality 550W – 600W supply will have, among other things, larger heat sinks to dissipate potentially more heat. It might have a larger fan too. The 400W supply will run most of the time closer to capacity, while the larger supply will be loafing along, rarely breaking a sweat. To help the smaller heat sinks get rid of the wasted 80 watts (20% of 400) of heat, the fan in the 400W supply may need to run full speed, while the fan in the larger supply, with bigger sinks just loafs along too – but in near silence.
Don't forget to budget for a good UPS with AVR (automatic voltage regulation). Surge and spike protectors are inadequate.
BrightWorks Systems B4
Windows 7 Profession 64-bit
Intel Core i7-860 Quad
Gigabyte P55-UD4P
Mushkin 4x2Gb PC12800
Gigabyte GTX260 896Mb
Integrated 7.1 HD Dolby
2 Samsung 2220wm-HAS 22"
1680 x 1050 | 1680 x 1050
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless Comfort 5000
MS Wireless 5000
Cable and pretty darn fast
Hi Digerati, thanks for your post :)
Isn't it legal to unload Windows 7 on my old computer, removing the serial and then using it on the new build? I am planning to run Windows Home Server on the old PC once the build finishes. I did this with Windows Vista, when i switched laptop once, as i thought that wasnt illegal as i paid for the Windows License. The Windows 7 i have is retail ;) But Vista was OEM :S
I will consider that advice, about buying it together ;) Problem is tho, that i would probably blow the money on something before i would have enough extra to buy all parts needed.
I've decided to go with the HAF 922 case, as i really like its military like design and easy tool less drive bays etc. Also the HAF cases have some very nice airflow which is always good.
You might be right about the RAM. I might want to go with either 6 or 8GB instead.I will consider that ;)
As far for optical drives, i will be using the DVD Burner from my current system as that system will be used for a server. (It will have an external DVD burner connected to it)
As i said i will not know what exactly PSU it is before next week. I will let you know what one it is by that time ;)
Excellent information, Bill. I thank you. I am going to build my first system later this summer.
Home built
Windows 7 Ultimate 32 bit
Intel(R) Pentium(R) 4 CPU 3.00GHz
ASUS P4P800-VM Motherboard Chipset: Intel 865G + ICH5
2.50 GB RAM
NVIDIA GeForce 7600 GS
SoundMax Integrated Digital Audio (Chip)
ViewSonic VX 1962 wm
1680 X 1050
Seagate Barracuda 7200.10 80 GB
ST380215A ATA Device 18.6 GB
Western Digital "My Book" external hard drive 750 GB
Fan based
Microsoft Comfort Curve Keyboard 2000 v10 USB
Logitec optic USB
3.01 Mb/s download 0.64 Mb/s upload
As I said, it is only legal if that copy of Windows 7 is a "retail" version. If it is an OEM or upgrade version, then, NO! It is not legal to use it on another computer. That's stealing and you would be a software thief. Please don't do that! I know most people think they paid for it, they should be able to do what they want with it, but they can't. That is not how software licensing works. And note this is not a Microsoft thing, it is a software industry thing. You don't own the software. You own a license to use it, and by using it, you agree to use it in accordance with the licensing. That is why it is called a EULA - end user license agreement. If you don't agree, go with one of the many capable and "free" Linux alternatives.
Understand that board has 4 memory slots and it supports dual-channel memory architecture. That means in order to take advantage of the benefits of dual-channel, you must use RAM in pairs. To get 6Gb on 4 slots (2 pairs) you would have to go 2 x 2Gb plus 1 x 2Gb. That would leave the second pair only half full. Or you could go 2 x 2Gb plus 2 x 1Gb. That would work, but then you have to make sure the 2Gb sticks are compatible with the 1Gb sticks. That's perfectly doable, but requires more homework before purchasing. That is why I suggested 8Gb so all 4 2Gb sticks could be the same.
And as I said, be prepared to toss it. Note I would rather have a 500W Antec or Corsair (for example) PSU than a 600W off-brand.
Gigabyte P55-UD4P
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless 5000
Systems by SmartEyeball
8 Pro x64
i7 3770K 4.6GHz
ASUS P8Z77 WS
x3 Dell U2410 / 58" Samsung
5760*1200/ 1920*1200
Noctua NH-D14
IE, FF, WaterFox
Bloody Big Grin
You are welcome Carl. Building your own is a great learning experience.
Gigabyte P55-UD4P
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless 5000
