You should upgrade or use an
alternative browser .
Slow speed, fast speed, slow speed.
I would ring them and ask them to do tests on the line yes, but at this stage its more likely to be your wireless connection.
Windows 7 Ultimate x64 Intel Core i7 2600K (O/C 4.7GHz) 8GB Corsair Vengeance LP, DDR3, 1600Mhz Nvidia GTX 460 Graphics Card Computer typePC/Desktop Computer Manufacturer/Model NumberCustom OSWindows 7 Ultimate x64 CPUIntel Core i7 2600K (O/C 4.7GHz) MotherboardAsus ROG Maximus IV Extreme-Z - Intel Z68 Chipset Memory8GB Corsair Vengeance LP, DDR3, 1600Mhz Graphics Card(s)Nvidia GTX 460 Graphics Card Sound CardOnboard Monitor(s) DisplaysDell E228WFP Hard Drives2 x 500GB Samsung SpinPoint Drives (1 for OS, 1 for Data and Apps) PSUCoolerMaster 1000W CaseCoolerMaster HAF CoolingAir Internet SpeedFibre - 60MB Down, 30MB Up AntivirusESET NOD32 Antivirus
And what else can I try on my own regarding my wireless connection?
Microsoft Windows 7 Ultimate 64-bit 7600 Mult... Intel i5 6600 8.00 GB GTX 1060 6GB Computer typePC/Desktop OSMicrosoft Windows 7 Ultimate 64-bit 7600 Multiprocessor Free CPUIntel i5 6600 MotherboardB150M-A Memory8.00 GB Graphics Card(s)GTX 1060 6GB
Changing it to 802.11b/g. You can try changing the wireless encryption to WPA2.
Dave
Hmm.. After about 10.30PM I had absolutely no troubles. Maybe I just need to change the wireless channel or something?
Did you try changing it to 802.11b/g?
You can try changing the wireless channel but because there are no other wireless networks in range it probably wont make any difference.
What's up?
Hello,
You're on Channel 6, it won't hurt to try changing the Wireless Channel to 1 or 11. The Xirrus shows a signal issue. Try moving your computer closer to the Router and see if it makes a difference.
Does your router have the latest firmware? Might want to find out.
Can you run another speedtest, this time use a wired connection and post the results here?
How's your wired connection? Is it better than the wireless?
Is 2mbps your signed up bandwidth from your ISP? Doesn't seem to be enough if you are a heavy gamer or others in your home are doing heavy online activities as well.
Win7 & Win8 64bit Intel i5 Computer Manufacturer/Model NumberLenovo Desktop/Samsung Laptop OSWin7 & Win8 64bit CPUIntel i5 Internet SpeedCharter-20 Mbps AntivirusAvast BrowserFF, IE9 and Chrome
Changed it to b/g. Not much difference.
Changed to channel 1,2,10,11 and none of them did anything different.
Wired works fine, but it's not a great option as I'm halfway across the house.
And yes 2mbps is what I signed up for. Australian internet = horrible
Two days ago the internet was working perfectly for 48 hours, for no real reason - it just started to work.
Then I had to put my router into a new PC and it began to show problems again.
Hi xChase,
Yes, I have heard very bad things about Australian Internet
As per 2xg's post, have you checked the Firmware version? (You will be an expert on this router before long lol).
Dave
All I can find on the interface page relating to firmware is this:
Hardware Version: 2701-100655-008
Whats your routers model number? I will have a look for a manual for you.
Dave
2wire 2701hgv-w. Perhaps the best option is a new router?
Ahh I was looking for one of these the other day with no luck! 2-Wire have very poor support on their products from what I have seen.
I would suggest a new router yes. If its just a standard ADSL connection then NetGear have always been relicable in my opinion.
Dave
Would it be wiser for me to use a D Link router considering that's the brand of my adapter? Or does it really not matter? And what type of router should I be looking for?
It shouldn't really matter as the routers will use the same encryption. However, if you are happier getting a D-Link router then go for it.
It maybe worth asking your provider for a recommended router. You need to find out if you're on ADSL/ADSL2+. They will be able to tell you what kind of router you need. I wouldn't buy it off them though as they can sometimes rip you off! If they recommend a 2-wire then hang up lol.
Dave
Just realised that it's not just the wireless computer, it's all of them. Even the machine connected to the router directly.
What's up?
A new router is a good idea, you may also try a reset to the factory default setting then reconfigure all from scratch. Do print screens of the router settings prior to the reset.
How to Reset a 2Wire Router | eHow.com
The settings are exactly the same as they were before I moved house. I honestly don't think it's anything to do with the settings because even the computer that's wired is slow as all hell.
As per zxg's post, try resetting the router.
If this fails, try as different router.
Dave
