SMPS fan is not running but motherboard is getting power
soaef
5:38 PM
Hello
Yesterday my PC shutdown ever 2-3 Hours without any reason.
So I decided to check it what's the problem ,so I just clean the RAM shot and remove the dirt from the case.
An I try to run my PC without closing the case,So when I turn on the power ,My motherboard is getting power signal(green light ) and when I start my PC ,my CPU fan start running but my SMPS fan is not running also I an not getting any display on my screen , also my hard disk light stop working .
Windows 7 Ultimate 32 Bit
Asus
Webroot
Hello
If the CPU is overheating (or failed), the system may be shutting down in self-protection. Have you been overclocking? Have you reset the motherboard settings to default?
7 x64 UltimateAMD Ryzen 516GB DDR4Radeon R7 360
7 x64 Ultimate
AMD Ryzen 5
Gigabyte GA-AB350-Gaming
16GB DDR4
Radeon R7 360
2 x Dell U2518D
2560x1440 2560x1440
WD 500GB x2
Samsung SSD 128MB (OS)
XPG SX8200 Pro M.2 2280 1TB
Antec 500
Hyper 212 EVO
Logitech cordless K800
Logitech M510
Avira
Hello
Replace the power supply. The fan in the power supply will be powered by a 12 volt supply which is also needed by the hard drives, motherboard and video card. :cool:
Windows 7 x64 Ultimate and numerous virtual m...AMD FX-8350 Vishera 32nm Technology @ 4.2 GHz...G Skill 32.0GB Dual-Channel DDR3 @ 1204MHz (1...EVGA GeForce GTX 960 4GB Super SC ACX 2.0+ wi...
Bluethunder II
LG L227WTG x 3
1680 x 1050 16:10
Rocketfish Full Tower
Logitech K740
500 mbs down and 30mbs up
i agree with roger. You should probably check your cpu fan for overheating. Also, indiana is right; if the video card, etc are not getting the proper voltage; then certain fans may function poorly or in this case not at all.
Windows 7 ultimate 64-bitIntel I7 2600K 3.4ghzCorsair 16gb ddr3 1600mhzNvidia Geforce gt 430
custom built
Asus Evo P8P67
Sound Blaster Titanium x-fi pci express
Dell E198WFP
1 western digital 2TB drive.
Antec 1200 watt
Inwin Dragon Rider
6 case supplied cooling fans
logitech mk700
logitech m705
25-50mbps download; 10mbps upload(i think)
avg free 2014
mozilla firefox
Also have a pretty bad speaker setup which is a klipsch promedia 5.1 surround speaker setup with huge subwoofer and lg blu ray player/writer. Also a hp officejet pro 8600 plus wireless all in one and a logitech s7500 webcam.
