Sound Driver is my problem? Realtek ALC663 Turned to High Def. Audio
Zombizee
1:04 AM
First off, I will not claim to be technologically gifted, so please be patient;
I've had a reoccurring issue with my Asus Laptop. Whenever I play music it starts to make this strange guttural sound, accompanied by bouts of freezing and frustratingly slow speeds and responses from my computer. It sounds incredibly similar to this youtube video I found researching my issue. ASUS G73 laptop stops and makes weird noise for a second (couple of times.) - YouTube
I've used my included recovery disk, and that fixed the problem for a couple months. But the problem returned, and at a loss for what to do, I decided to try to uninstall my sound driver, with the intention of reinstalling it. I restarted and was presented with a new driver "High Definition Audio Device." I don't want to irreversibly destroy anything by continuing this blind voyage. What do I do next? Is it my sound card at all?
Windows 7 Home Premium 64bitIntel Core 2 Duo CPU P8700 @2.53 GHz6144 MB, DDR2-6400, 3x 2048 MByteNVIDIA GeForce GTX 260M - 1024 MB, Core: 500 ...
ASUSTeK Computer Inc. ASUS Notebook G72GX Series
Intel PM45
NVIDIA GeForce GTX 260M - 1024 MB, Core: 500 MHz, Memory: 80
Realtek ALC663 @ Intel 82801IB ICH9 - High Definition Audio
17.3 in. 16:9, 1600x900
Seagate Momentus 7200.4 ST9320423AS, 320GB 7200rpm Two hard disks with 320 GByte each
its microsoft driver for HD audio device you should not worry. your device is still the same but with microsoft driver.. if you reinstal realtek driver, device name should be back from generic Hd audio.
but if you have problems with your realtek driver please try to download new version..
you can find information here http://www.sevenforums.com/sound-audio/3756-latest-realtek-hd-audio-driver-version.html
or stick with microsoft driver (you will lose some functionality compared to realtek driver but sound shuld work) and maybe it will solve you problem.
Windows 7 pro 64bit. (SP1)Intel core I5 24008GB DDR3 KingstonGigabyte GF GTX650OC
Self Built PC
Intel core I5 2400
Gigabyte H61
8GB DDR3 Kingston
Realtek HD audio
LCD 20"
1600x900
INTEL SSD 320 80GB +Seagate 7200.12 1TBx3
Coolermaster RX450W
Coolermaster atx case
stock cooler
logitech
logitech
FTTD 100mbps
