Strange problem and sfc /scannow also not able to solve it.
firewire
9:14 AM
hi,
i am having some strange problems with my pc going on lately i am not able to open wmp then i downloaded feed demon and opened it , it was working properly but when i click on a site it tells me to download small html files for each and every site which is very annoying and i cannot view that site in feed demon itself i have to view it in my default browser.So for me feed demon is of no use.
i also found that my pc has some issues with jscript.dll.i don't know how i found that error but some software showed that jscript.dll was having error .So i used sfc /scannow command and it told that it cannot repair some stuff as shown in the image attached.
i have also tried to repair using installation disc but it repairs only boot problems.i don't have any system restore points.
thanks.
  • sfcdetails.txt
    sfcdetails.txt
windows 7 64bitAMD ATHLON II X2 245 (REGOR 45nm TECHNOLOGY)2.0GB SINGLE-CHANNEL DDR3 @ 534MHz 7-7-7-20DELL IN1910N @ 1366x768 [ATI VIDEO (GIGABYTE)]
windows 7 64bit
GIGABYTE TECHNOLOGY Co., Ltd. GA-MA74GMT-S2(SOCKET M2)
REALTEK HIGH DEFINATION AUDIO
1366x768
488.39GB SEAGATE ST3500418AS ATA DEVICE (UNKNOWN INTERFACE)
System Restore to a point before the problem started.
Windows 7 Ultimate RTM (Technet)3.00 gigahertz Intel Core2 Duo E84004GBATI Radeon X1950 Pro
ASUSTeK Computer INC. P5K/EPU Rev 1.xx
4GB
Built in HD Audio
22" Gateway LCD
1920 x 1200
ST3160023A [Hard drive] (160.04 GB) -- drive 0, rev 8.01, ST3500630AS [Hard drive] (500.11 GB) -- drive 2, rev 3.AAK
ST3500630AS [Hard drive] (500.11 GB) -- drive 1, rev 3.AAK
Logitech G11
Microsoft Wireless Laser Mouse 5000
13.44 Mbps
Are you sure you don't have any system restore points? Those are usually store automatically.
Windows 7 Pro x64Intel Core i7-5820k32GB Kingston HyperX FURY DDR4-2400EVGA Geforce GTX970
Windows 7 Pro x64
Intel Core i7-5820k
ASUS X99-PRO
EVGA Geforce GTX970
ASUS VC239h
Samsung 850 EVO SSD 250GB x2
750 GB HDD
3TB HDD
Corsair RM750
Fractal Design Define R5
Noctua NH-D15
Corsair Strafe RGB
Logitech G502
I don't have it all as it was off and i don't know when probe started as i discovered it now :( .
windows 7 64bit
1366x768
Put your installation DVD in and try a repair install.
win7
win7
As i mentioned i tried using installation disc but of no use it repairs boot sector and in my case there no problem in boot sector.If There's other way to repair can you elaborate please.
windows 7 64bit
1366x768
Ok thanx for explaining me .I have sp1 but my installation disc is without it .I have sp1 offline installer with me .So can i uninstall sp1 and then repair my pc and again reinstall it??
You were running Startup Repair which is booted to repair Win7 boot when it won't start, not a Repair Install which is run from the desktop since Vista.
If you have SP1 you'll need a WIn7 installer with SP1 (not slipstreamed) or you'll have to uninstall SP1 to run the Repair Install: uninstall Windows 7 Service Pack 1 (SP1)
If Repair Install cannot repair your issues, you may need to consider clean Reinstalling Windows 7
windows 7 64bit
1366x768
Yes, if SP1 will uninstall you should be able to Repair Install.
If not, you'll need to find an installer for your version with SP1.
OK thanks.but will i lose my stuff or evry thing will be intact as in willi need to backup???
windows 7 64bit
1366x768
You should always keep your files backed up. Most modern tech-smart people keep an image backup too, especially since it's built into Win7: Backup Complete Computer - Create an Image Backup
That said, I have never seen a case of a Repair Install failing with file loss. Even if Win7 becomes unbootable, the files are almost always recoverable. But back them up regularly anyway.
Agreed Gregrocker, OP:- the repair install should not corrupt your files or user settings, but follow Gregrockers advice and backup..just in case!! Good luck
win7
win7
thanks everyone will give it a try and post result ASAP.
windows 7 64bit
1366x768
Ok i tried to remove sp1 but i am not able to remove it gives me error as shown in image.
Now what should i do. i have offline installer of sp1 but of no use.
windows 7 64bit
1366x768
Personally, I would try doing a repair-install and then re-apply SP1.
win7
win7
I have solved problem without uninstalling sp1 or reinstall or format
windows 7 64bit
1366x768
How?
Might be useful to someone else with the same issue.
    7 X64i5 84002x8gb 3200mhz
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    pure power 11 400w cm
    Coolermaster
    cryorig m9i
    7x64g54008gb ddr4 2400
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
I unistalled ie9 which had some issues with jscript.dll and i reverted back to ie8 which has solved my pc probe.i am not able to figure out why this happened and such thing shouldn't happen.
windows 7 64bit
1366x768
