Strange problem with BF3. Help!
Kriswithak
5:38 PM
So, This problem also happened in the Beta of the game, i wrote it off as a problem with the Beta. When i'm playing BF3, My game will crash and when i AltTab BF3, my screen is in negative colors, then when i end the process from Task Manager, Everything goes back to normal. In-game, everything is fine, game play great. I'm thinking it's an system inadequacy problem.
Windows 7, 64bit
Dell XPS L502X
Nvidia gtx 580
6 GB RAM
64 bit Widows 7 Premium
The core engine of certain video games simply don't support the "AltTab" function and switching between the game and any other program running. It's always a bad idea to do so as it sometimes may create video hardware errors (i.e. GPU driver error) which could explain the strange color problem.
Not only that, but many games present some kind of weird picture artifacts when the game freezes and you want to use the Task Manager to kill the process. This is nothing unusual.
As for the crashes themselves, are they created beforehand or after you AltTab the game?
Intel Core i5 2500K
MSI MS-7750
8GB DDR3
nVidia GeForce GTX650 Ti BOOST
Realtek
21' Philips
Full HD
1TB
500W
The crash occurs before, I AltTab to get out of the already crashed game.
try lowering your resolution, it might help
Windows 8.1 - 64 Bit
Intel Core i5-4670K (Haswell)
Gigabyte GA-Z87X-D3H
8GB DDR3-RAM PC1600 CL9 ADATA XPG V1.0 black
Gigabyte NVIDIA GTX 770 Graphics Card (2GB, DDR5, PCI-E)
ASUS Xonar DX 7.1 | Turtle Beach HPA 2
Samsung SyncMaster P2270HD
1080p
Samsung 840 Evo 250 GB (OS only)
Seagate Barracuda 1TB S-ATA
Seagate Barracuda 250GB S-ATA
Maxtor 250GB S-ATA (Backup only)
WD Elements 500Gb/Go
750 watts
Zalman GS-1000 Special Edition
Zalman CNPS10X Performa
Logitech K350
Logitech M705 | Razer Vespula Mouse Pad
Virgin Media - 60Mbps
120mm fans x 4
(2 on top, 1 at rear, 1 at bottom)
You don't specify what CPU you have but, by association and by looking at your Video Card (it is a very good Card), I think it should be at least a Quad Core.
Now, being said that, I friend with same Specs I have a Q9650. 8GBs of Ram and a GTX260 had no problems with the game. It did receive a notice the first time the game was opening that it needed to upgrade to the latest Nvidia Drivers (Ver 285.26 I think it said?) so my advice to you is...
Download the latest drivers for your Video and Audio Cards, save to a safe locations, uninstall old drivers, restart, uninstall PhsyX as well, restart to safe mode, run the Driver sweeper, restart and install both new drivers with Elevated admin rights (right click on exe and Run as Administrator).
Good Luck
Custom Built... Intel/Nvidia/ASRock
Windows 7 x64 (Ultimate)
Intel i5-4670K
ASRock Z87 Extreme 6
8GBs Ripjaws 2133Mhz
Asus GTX660 (2GBs)
Onboard Realtek HD
Acer AL2216W
Samsung 840 SSD 120GBs
Samsung 750GB 32MB cache
1.5 TB
PC Cooling 750w Silencer
Thermaltake Spedo Advance
Std Cooler
Logitech G15
Logitech G9
Comcast 20Mbit
its a laptop which comes with i5-2410M CPU @ 2.3Ghz
1080p
750 watts
Logitech K350
120mm fans x 4
Intel Core i7-2630QM CPU @ 2.00 GHz, I overclock to 2.75
1080p
750 watts
Logitech K350
120mm fans x 4
Does it still happen when things are at stock speeds? Also hope you have a good cooling pad or something as just because you can, overclocking a laptop isn't really a good idea.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Hello everyone,
I have similar crashes usually when playing in a huge map(the ones with planes).The game freezes with repeating sounds and I'll have to end the process manually....
Do you think the problem might be that i have a 2 CORE cpu running next to my GTX 460 1GB ?(check specs also for detailed info)
Windows 7 ultimate 32bit
AMD Phenom II X2 3,2 GHz Black Edition
GIGABYTE GA-MA74GMT-S2
4GB DDR3 1333MHz
GTX 460 SE 1GB
Integrated Realtek
HP w2007v
400GB HDD
Xilence Redwing 580W
HP m8000
CPU Cooler Master V8
Even in SP, some scenes are badly glitched on my rig, too. The FPS would drop somewhat, but the sound gets repeated halfway through a word or a sentence. I wrote it off due to my bad rig, though, and got through it without any serious problems.
Intel Core i5 2500K
MSI MS-7750
8GB DDR3
Realtek
21' Philips
Full HD
1TB
500W
loading bf3
from disc error msg reads os needs updating. I have the latest and greatest os and gaming soft/hardware. need help
windows 7 ultimate 64 bit
