Surround System Problem
aliawaiskhan
3:54 PM
Hey everyone,
I installed windows 7 today, I'm a big fan of hooking up my comp to the TV and watching movies. It was a pain to get the video card working but all is good now. When i thought I was ready to start watching some quality TV, I came across an even bigger problem: Only 2 of my speakers were working, i went to the hardware and sound configs in the control panel and set it to 7.1 surround, sure enough it recognizes all of them, when i test it all 7 speakers and the subwoffer work perfectly, however no other program is using them, they all only use 2 speakers
I've tried winamp, vlc, windows media center, media player classic and it happens with all of them.
Help!
Windows 7 64-Bit
Core i7
Msi Eclipse
Corsair 2GB*3 1600Bus Speed
Msi Gtx 295
Creative Xifi Xtream
View Sonic 2262
1680*1050
Segate 1TB
Coller Masteer 750W
Coller MAsster HAF932
Coller Master Z600
Hey everyone,
Help!
Hi and welcome
It is still probably a driver issue. can you check device manager to see if your driver is installed, and working properly.
type device manager in search>sound tab>Is your device listed? is there a yellow triangle on it? are there any other "unknown" devices?
Kenn J+
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Please see...
There is no yellow triangle on it....
Windows 7 64-Bit
Core i7
Msi Eclipse
Msi Gtx 295
View Sonic 2262
1680*1050
Segate 1TB
Coller Masteer 750W
Coller Master Z600
:cry: Still no reply.......
Windows 7 64-Bit
Core i7
Msi Eclipse
Msi Gtx 295
View Sonic 2262
1680*1050
Segate 1TB
Coller Masteer 750W
Coller Master Z600
I have the same sound card as you but when I checked it in Device Manager, mine names the device as "Creative SB X-FI" and that's it. Yours has "Vista" added at the end.
Are you sure you have the newest drivers installed?
After installing Windows 7 / 64 a few weeks ago, I went to the Creative site and downloaded and installed the latest version on the driver and software packages for the card. I've had no sound related problems since.
Good luck... you have good taste in sound cards, by the way!
Windows 7 /64
Orlander Thanks for reply.
I go to updates and update my sound card too now i am enjoying my 7.1 :party:
i have also corei7 and a heavy duty GTX 295 Gaming Card :p
Windows 7 64-Bit
Core i7
Msi Eclipse
Msi Gtx 295
View Sonic 2262
1680*1050
Segate 1TB
Coller Masteer 750W
Coller Master Z600
Hey everyone,
Help!
If i'm not mistaken, don't you have to set the sound options in each program to 7.1 to make it effective?
W7 RTM Ultimate x64
Intel Q8400 @ 2.66GHZ
Gigabyte GA-EG45M-UD2H
4GB DDR2-800
Integrated 8 Channel
AOC 23.6 Inch Widescreen LCD
Seagate 500GB Internal
Western Digital 1TB Internal
Hitachi 1TB External
Apevia Java Power 500W
Cooler Master HAF 922 Black
Stock Intel CPU Fan
1.5MB
I checkd and verify there is no need to set the sound option in each programe
Windows 7 64-Bit
Core i7
Msi Eclipse
Msi Gtx 295
View Sonic 2262
1680*1050
Segate 1TB
Coller Masteer 750W
Coller Master Z600
You are welcome.
I have to hand it to Microsoft. Windows 7 is so much better then XP.
Nice setup you have there. I have the EVGA GTX 275 with a Q9550 quad. No i-Core in my near future... need a job first :(
Windows 7 /64
