Solved System Repair USB not working but System Repair disc is.
Gandolf
12:46 AM
I have decided recently to create a system repair disc in case something goes wrong with my computer. Using recdisc.exe, I created a system repair disc and everything worked out fine. Once I booted with the repair disc, I got a screen that looks like this:
This is what I wanted
I decided to make a recovery USB as well for convenience. (USB is much faster and is less bulky than a regular DVD)
I copied everything in the DVD, and pasted in my USB (the USB is an active and a primary partition). When I boot into the USB however, I do not get the System Recovery Options screen, but the HP Recovery Manager screen. I personally dislike HP recovery manager and want to get the Windows System Recovery Options screen.
If I try to close the HP Recovery Manager, a dialog pops up asking if it should close HP Recovery Manager and reboot. Can someone tell me if I did something wrong to create the USB Recovery drive? I don't know what I did wrong, I copied everything from the disc (which works perfectly) to the USB (which suddenly decided not to work.) In case anyone was wondering, the HP Recovery Manager looks like this:
I don't know if this is relevant, but the CD drive is first in my boot order. Once I have a repair CD in my computer, it automatically loads. For me to access the USB, I have to manually boot into the USB using BIOS. Thanks for reading.
Windows 7 Home Premium 64bitIntel i5 355010 GB DDR3GTX 550 Ti
HP
Intel i5 3550
http://h20564.www2.hp.com/hpsc/doc/public/display?docLocale=
10 GB DDR3
GTX 550 Ti
1 HDD
1 SSD
CX 500
Default HP Case
Default Air Cooling
Webroot
HP
Intel i5 3550
10 GB DDR3
GTX 550 Ti
1 HDD
1 SSD
CX 500
Default HP Case
Default Air Cooling
Webroot
Hi
you cant just copy and past it into the usb drive it has to be bootable. i have not done it before but see if this helps you. http://www.sevenforums.com/tutorials/92177-boot-windows-7-system-repair-disc-usb-using-grub4dos.html
Thanks for the quick reply! I will follow the tutorial and will update whether I was successful or not.
This partially worked out, I managed to get to this screen:
On my CD Repair disc, Windows Recovery Options detects the OS fine. It cannot on the USB however.
HP
Intel i5 3550
10 GB DDR3
GTX 550 Ti
1 HDD
1 SSD
CX 500
Default HP Case
Default Air Cooling
Webroot
Is a screen print missing in post #4 ?
home built
AMD Athlon II x4 620
Gigabyte GA-MA785G-UD3H
6GB GSkill DDR2 800
AMD 4670 GPU + AMD 4200 IGP
on board Realtek ALC889A
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
Avast, MBAM3, EMET, WinPatrol
Pale Moon, Firefox, IE
2 multi-boot PC's
Trendnet USB KVM.
HP
Intel i5 3550
10 GB DDR3
GTX 550 Ti
1 HDD
1 SSD
CX 500
Default HP Case
Default Air Cooling
Webroot
in post 4 the image is not showing
win 10
dell xps 9000
win 10
TY @oscer1 !
@Gandolf - Look at what you see in this thread for your post #1 and post #4...
home built
6GB GSkill DDR2 800
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
2 multi-boot PC's
Trendnet USB KVM.
TY @oscer1 !
That's strange... On my screen, it shows up clearly.
EDIT: I just posted actual links to the pictures I was talking about.
HP
Intel i5 3550
10 GB DDR3
GTX 550 Ti
1 HDD
1 SSD
CX 500
Default HP Case
Default Air Cooling
Webroot
Well, here's what i see for post #4
home built
6GB GSkill DDR2 800
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
2 multi-boot PC's
Trendnet USB KVM.
Does the puush link work for you though?
HP
Intel i5 3550
10 GB DDR3
GTX 550 Ti
1 HDD
1 SSD
CX 500
Default HP Case
Default Air Cooling
Webroot
I don't see or know what the "puush link" is.
You inserted images in post #1, so you know how to do it.
I don't click on external links to view an image ...
home built
6GB GSkill DDR2 800
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
2 multi-boot PC's
Trendnet USB KVM.
I edited Post #4 to include a puush link directly to the picture. The pictures in post 1 were not very important, the image in post 4 is though. Here is the puush link again: http://puu.sh/eTjHn/41862bd5e5.jpg
That's what I meant when I said puush link.
HP
Intel i5 3550
10 GB DDR3
GTX 550 Ti
1 HDD
1 SSD
CX 500
Default HP Case
Default Air Cooling
Webroot
Push, shove, turn upside down or what ever you want to call it.
This Tutorial below is the best way to post pictures on this forum. I also don't tick on hyper links to see pictures. It's not safe because we don't have any idea where the link is going to send us.
Tutorial by brink:
Using this tutorial will send a picture from your computer to the forums computer and in your post. No Man In The Middle. It's safer and easier for us to give help.
Changed the image on post #4, does it work now?
HP
Intel i5 3550
10 GB DDR3
GTX 550 Ti
1 HDD
1 SSD
CX 500
Default HP Case
Default Air Cooling
Webroot
EVERY image is important to anyone trying to help you here in Seven Forums.
A picture is worth a thousand words.
home built
6GB GSkill DDR2 800
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
2 multi-boot PC's
Trendnet USB KVM.
We posted at the same time.
I can now see your image in post #4 :)
home built
6GB GSkill DDR2 800
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
2 multi-boot PC's
Trendnet USB KVM.
I actually just found a fix to my problem xD Turns out, the boot files on my USB were corrupt for some reason. I just re-installed the ISO and it worked out fine.
HP
Intel i5 3550
10 GB DDR3
GTX 550 Ti
1 HDD
1 SSD
CX 500
Default HP Case
Default Air Cooling
Webroot
ok thanks for the fix
win 10
dell xps 9000
win 10
home built
6GB GSkill DDR2 800
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
2 multi-boot PC's
Trendnet USB KVM.
