Water cooling help
D3LL
Pro User
9:00 AM
United Kingdom
Hi guys, I think its time i done a fully water cooled system rather than a h70.
I have an Antec 300, Could I fit 2 radiators together at the back and the top fan mount?
I'm not sure if there will be enough room?
Me :D
AMD X6 1090T 4.02Ghz
ASUS Crosshair IV Formula
16.00GB
Nvidia Geforce 470
ASUS Xonar DX
Dell 24" Monitor
2TB WD
1TB WD
2TB WD
60 SSD
60 SSD
700W Crosshair
Antec Three hundred
Water Cooling
You could fit a 240 or 360mm rad if you use Swiftech's Radbox which would mount on the rear of the case and would attach to the rear fan port, you could then feed the hoses through an available expansion slot or drill appropriately-sized holes in the back to feed the hoses through (don't forget the grommets!).
I don't know how much space you'd have without sawing (there's a template at the front of the case which appears to be for two 120 fans), but you may be able to fit a single 120 rad into the loop by fitting it to the top fan port.
Windows 10 Technical Preview - x64
Core i5-3570K - 4.5GHz
ASUS Sabertooth Z77 [B. 2003]
G.Skill Sniper 12GB DDR3-1600
ASUS GeForce GTX 970 STRIX
Acer K272HUL
Samsung 840 Evo 250GB (OS), Samsung Spinpoint F3 HD103SJ 1TB (Games), Seagate Expansion 1TB (Additional storage, Backup)
Cooler Master Real Power Pro 750W, Corsair HX1000W
HAF-X
XSPC Rasa RS360
Gigabyte Osmium, Noppoo Choc Mid 87, Corsair K70 RGB
Roccat Kova
50 Mbps up, 50 Mbps down
BitDefender TS 2013, Malwarebytes AM, SUPERAntiSpyware
Razer Vespula Gaming Pad, Razer eXactMat, Blackmagic Intensity Pro, Corsair Vengeance 1500 USB Headset, Google/ASUS Nexus 7
Discovered I won't have enough room for this after using measuring up. I think i may go with a Corsair 650D case. Now I need to decide on which blocks etc i need.
Me :D
16.00GB
Nvidia Geforce 470
ASUS Xonar DX
Dell 24" Monitor
2TB WD
1TB WD
2TB WD
60 SSD
60 SSD
700W Crosshair
Antec Three hundred
Water Cooling
If you want to put a lot of radiators in, consider the NZXT Switch 810. It will hold a 420-480 in the top, a 40 in the rear and a 2X 120 in the front floor or against the front fans. It has a couple extra features also, and comes in 4 colors.
My Computers
    ALWAYS UNDER CONSTRUCTION
    Windows 11 Pro
    Ryzen 9 5900X
    Asus X570 Crosshair Viii Hero
    32GB G Skill DDR4-3600
    EVGA RTX 3080 FTW 3 Ultra
    3 X Asus 27"
    2 X 1 TB NVME drives
    EVGA 850
    Phanteks Eclipse P400A
    EVGA 280 AIO
    Logitech G510s/ Logitech G13
    Logitech G502
    ESET/MBAM Pro/SAS Pro
    Chrome/ Firefox/ Edge
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
I can't stand full towers, sorry lol.
Me :D
16.00GB
Nvidia Geforce 470
ASUS Xonar DX
Dell 24" Monitor
2TB WD
1TB WD
2TB WD
60 SSD
60 SSD
700W Crosshair
Antec Three hundred
Water Cooling
Have a look at the water cooling guide in the same section: http://www.sevenforums.com/overclocking-case-mods/233104-water-cooling-guide.html. As for blocks, I would say XSPC, they have the lowest tested restriction rate of all cpu blocks, and the raistorm fits on several different cpu platforms,so its a great value for money. Secondly I would go for Swiftec, they have excellent warranties and low restrictive blocks, but first choice would still be XSPC. I don't know if you purchased anything yet, but for a 650d chassis I would get the Swiftec 355 pump with pump top, on that I would ad a 140 mm reservoir from EKWB, or if you can fit it a 250mm, connected to the raystorm XSPC cpu block,running 7/16 tubing on 1/2x3/4" fittings will give a better seal, or get same size tubing as your fittings but make sure they are compression fittings. Then for rad I would go for the XSPC if you plan on getting lowed high rpm fans. or get the Swiftec/Koolance v series if you want low rpm fans. Then tubing must be primo chill-primo flex, get the best! Color is your choice. And I would use distilled water wither a silver kill coil, but if you want colored liquid go for primo chill.
Custom built
64bit Windows 10
Intel i9
MSI X299 Carbon pro
64g-8x8gig DDR4 3600
Asus ROg Strix 1080ti
Samsung 49" Odyssey g9
5210x1440
1 x 512GB m.2 OS Drive
2 x 512gb ssd
1 x 2tb
4x 1TB's
Corsair AX1200w
Silverstone TJ11 B-W
AIC
Asus Rog Claymore 2
Asus Rog Apatha
1gb Fibre
Alsisgevat, Maybe I misunderstood the tut, but the XSPC rad on the RX360 is saying 8FPI. I understood that means you can use low RPM fans.
My Computers
    Windows 11 Pro
    Ryzen 9 5900X
    3 X Asus 27"
    EVGA 850
    EVGA 280 AIO
    Logitech G502
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
Yup it does,:o,my bad I mixed the two up,but good eye and thanx for correcting me:D
Custom built
64bit Windows 10
Intel i9
MSI X299 Carbon pro
5210x1440
2 x 512gb ssd
1 x 2tb
4x 1TB's
Corsair AX1200w
AIC
Asus Rog Claymore 2
Asus Rog Apatha
1gb Fibre
