Win7 Style Builder Problem | Problems Opening msstyles
iRush Pro
Intel Core i5 2500K Processor
Intel H67 Chipset Motherboard (Micro ATX)
2x4GB DDR3 1333Mhz Memory
Novatech Radeon 6770 1GB Graphics Card
1TB
Novatech 500W
Novatech ATX Gaming Case
Novatech Wired Keyboard
Novatech Wired Mouse
VirginMedia 10MB/s
Sager NP9170
Win 7 Pro x64 / Win 10 Pro
CLEVO P170EM
12 GB
Backlite
MSE, Malwarebytes Pro
DESKTOP: Custom-built.
OS: Win 10 Pro x64.
CASE: Rosewill R5.
MOTHERBOARD: Asus Z87-A.
GPU: Nvidia Geforce 650 TI.
PSU: Corsair TX750.
Steps I followed:
1. Created a new theme/msstyle the correct way, by copying the No_Glow_2 theme previously provided as a starting point. Named it EasyRead2.
2. Used Windows Style Builder to change the inactive window border opacity to the same as the active border's, changed the selected item color to grey in most instances. Overwrote EasyRead2.msstyles and applied it. (I did have some error messages about there being an error in the msstyle, but no idea why, and it did save upon a second attempt).
3. In the Personalize menu I changed the border color to black, and unticked enable transparency; thus creating an 'unsaved theme' because I had edited things. I 'saved this theme for sharing', then unzipped the .themepack to retrieve the .theme file.
Hopefully with any luck this new file will work for others, and if it does it doesn't revert it's changes at a later date for some reason:
https://rapidshare.com/files/2274504700/EasyRead2.theme
iRush Pro
1TB
Novatech 500W
VirginMedia 10MB/s
You need the name the same in all 3 places you need the "2" added
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
Ah, my mistake in the above explanation. Everything was named "EasyRead" in my creation steps. Until I got to the saving of the unsaved theme, and saving that for sharing. I named that "EasyRead2" (funnily enough, to avoid confusion, that didn't work.)
i need help to do this myself, I just purchased style builder and need help modding my theme. can you please give me instructions on how to remove the text glow.
id also like to change the text color at the top to white only on the active menu.
after a bit of messing about i finally removed glow. now what do i do to change text color to white?
win7 pro 32bit
3gb
2x140gb
5mb per sec
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
alrite doine this
win7 pro 32bit
3gb
2x140gb
5mb per sec
alrite doine this
You can change that text color at Fonts, Colors & System Metrics > Fonts & System Metrics > CAPTIONTEXT:COLOR but that changes the text on both active and inactive Windows there's no way make them separate.
For programs like Firefox you can go to Windows and Caption Buttons > Aero > Dwm Window > Frames > Normal > Top > MaxActive > TEXTCOLOR:COLOR
Windows and Caption Buttons > Aero > Dwm Window > Frames > Normal > Top > MaxInactive > TEXTCOLOR:COLOR but this is for when the Window is maximized.
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
cheers jerry this worked for maximised window only. how do i make it so it is white even when not maximised
win7 pro 32bit
3gb
2x140gb
5mb per sec
That changes the text on both active and inactive Windows.
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
well that changed the font for everything i cant read any text without it selectd
win7 pro 32bit
3gb
2x140gb
5mb per sec
You changed Fonts, Colors & System Metrics > Fonts & System Metrics > WINDOWTEXT:COLOR
You need to change
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
  • Like
Reactions: JMH
ah that helped but if i save it using personalisation it reverts it. also how do i remove the more than window open glow and change text to white. also some programs like paint still have a glow around even though some dont since i removed it.
also how do i change the bar color to complete grey without gradients and the text color of this. not the folderband text color
win7 pro 32bit
3gb
2x140gb
5mb per sec
I do not know about personalization reverts?
That black text should have changed when you changed the text to white at Fonts, Colors & System Metrics > Fonts & System Metrics > CAPTIONTEXT:COLOR
The glow on paint look at screenshot.
You can join here because you purchased Windows Style Builder Look at #4 Address Bar here Login
or here sign up is free Complete Guide to Theme Building
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
ok i think its this.
Address, Breadcrumbs & Search > Address > Address Band > Basic > Address Band > <1>
but modifying the image seems really confusing to me.
if i want it grey is this good
win7 pro 32bit
3gb
2x140gb
5mb per sec
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
i still dont really get it. could you please make me one for plain grey. hex #333333
i dont even know what "hot" means
win7 pro 32bit
3gb
2x140gb
5mb per sec
i dont really get it. could you please make me one for plain grey. hex #333333
That 1 image has 4 parts Normal, Hot, Disable, Hot Selected each part is 7 x 23 pixels color each to your liking.
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
