Hi guys... new to this forum
My comp specs follows:
M.board: biostarTh55b HD (t seiries board)**
Intel i3 CPu 530@ 2.93 ghz
Crosair Memory: 4gb dual channel DDr3 (CMV4GX3M2A1333C9)
Raidmax mod # Rx -380 k (power supply)
Segatge Barracuda 7200 HD
please let me know if there is more info I should have for specs//
If I can explain properly is as follows: When the computer is shut down for a period of time (usually left over night) upon rebooting.. (pressing the on switch), it brings me to the start up repair/start normal screen. If i repair or start normal i am sent to a loop that usually send me back to repair/srt normal screen after (Tseries board screen)**
If i manual cut power at power supply and restart the computer it usually will restart without a hitch. (This means i must manually click the power button on the back of computer on the power supply or unplug computer from wall...)
I have tried to check memory when i start at the bios screen by pressing i believe f11 (for me) and the check has not found anything wrong.
The computer usually runs flawlessly when i have it running but I have had a couple of blue screens.
I have recently wiped the hard drive and done a full new re_intsall of windows 7 64 bit and that has not seemed to solve any of the problems.
I hope someone can help me or knows if this could be a certain kind of problem so that I can eliminate things that it def is not
Thanks everyone in advance and please feel free to ask me to post more info as I am a real newb when it comes to this stuff
windows 7 64 bit
- windows 7 64 bit
