Wireless Network Adapter Problem Airpace WiFi Abit
In the Link i Posted you will see the following >> Method 2: An alternative driver can be found here (this one worked for me ]
Try that Driver it is a direct Download ...
windows 7 home 64bitINTEL-CORE I716GB
W530-3630QM1
INTEL-CORE I7
16GB
750GB
When i update Nvidia...it says: Windows has determined the driver software for your device is up to date.
And when i update the network controller to it says:Windows could not find driver software
and nothing happens still no WiFi
Windows 7 64 bit2x2GB RAM
Windows 7 64 bit
2x2GB RAM
1600x1200
The Nvidia is fine and working if you wanted to use that you need to connect it to your Router by a Cable connection ...
W530-3630QM1
INTEL-CORE I7
16GB
750GB
I cant my parents hate when they see cables in the corridor, somehow i have to fix that Network Controller.Any more ideas?
Windows 7 64 bit
2x2GB RAM
1600x1200
In Post 21 did you try that Driver ? ....
W530-3630QM1
INTEL-CORE I7
16GB
750GB
Yes I tried it and explained what happens after I did it, it said that can't find any drivers (when in the device manager I choose update than browse the location of the driver )
Windows 7 64 bit
2x2GB RAM
1600x1200
Exactly the same driver as others, even my laptop is putting (2) in the end of the name, that means it is the third time i am downloading that driver
Windows 7 64 bit
2x2GB RAM
1600x1200
I guess you are out of luck then .. You could get a USB Wireless Adapter they not very expensive ...
W530-3630QM1
INTEL-CORE I7
16GB
750GB
No, I think to buy something like that but newer model without driver problems, because I'm not sure if the flash drive works fine.Thanks for the efforts.Kind regards!
Windows 7 64 bit
2x2GB RAM
1600x1200
Are your USB Ports not working ? ...
W530-3630QM1
INTEL-CORE I7
16GB
750GB
They are working ,today I bought USB wireless adapter and it is working fine with it
Windows 7 64 bit
2x2GB RAM
1600x1200
That is good news :)
W530-3630QM1
INTEL-CORE I7
16GB
750GB
