Wireless stopped working, can't power on 'wireless radio
Docfxit
Power User
4:58 PM
I have had this problem not being able to turn on the wireless radio for months. I have to get it turned on now. I would appreciate it if someone could help me get turn it on. I have done a number of things to try to resolve the issue.
When I press <fn> F5 I can see the wireless radio is off. I see the power on button. When I select the power on button nothing happens. I expect the wireless radio to power on.
I have tried fixing the winsock. I have run this MS fix at:
How to determine and to recover from Winsock2 corruption in Windows Server 2003, in Windows XP, and in Windows Vista
And I have run this bat file
** Start of bat file called renew-ip-reset-winsock.bat
ipconfig /release
pause
ipconfig /renew
pause
netsh winsock reset catalog
pause
netsh int ip reset reset.log
pause
** end of bat file
I have tried uninstalling , rebooting and reinstalling the wireless driver.
I have removed the following software in this order:
Power Manager Driver
Power Manager
Hotkey Utility
Wireless NIC Driver
Access Connections
I have re-installed the above software in the above sequence.
1.LenovoThinkPad Power Management Driver ver.1.62 83ku14ww.exe
2.LenovoThinkPad PowerManagerVer. 3.62 8ru410ww.exe
3.LenovoHotkey Features Integration ver. 3.52 8mvu32ww.exe
4.Lenovo ThinkPadWirelessLan11bgnVer.1.00.0029.2 6iws24ww.exe
5.LenovoAccess Connections ver. 5.84 83c755ww.exe
I have tried fixing it by re-installing the Ethernet wired driver:
6.LenovoRealtekLanDriverVer.7.7.1002.2009 80r852ww.exe
I have tried fixing the problem by making sure this registry entry was set properly.
1. regedit
2. [HKEY_LOCAL_MACHINE]\System\CurrentControlSet\Services\ndisuio
3. Change Start to "0x000000003 (3)"
4. Restart
I have installed a different hard drive and restored the Lenovo CD's. The wireless radio works fine. So I know the hardware is working fine.
I have no red exclamation marks in Device Manager. I have nothing called other in Device Manager . I have no devices with a yellow explanation mark.
The wireless device is enabled and working fine.
I have changEd the settings on Power manager .
You need to go to Globalsettings on Power manger (you can double click Battery to get there)Then you need to click on advanced settings .Under Power mangement click so it shows Disable for CPU and PCI Bus . This will not hurt computer but it will keep your computer from shutting off wirelss card to save power .You will need to restart for change to take effect . Also make sure Battery stretch is disabled . Finally
choose maximum performance as scheme name .
I have all ms updates on the machine.
The laptop is running Win7 professional sp1
3gig memory
64bit
Thinkpad Model 4444 CTO L512
Does anyone have any idea what might turn on the wireless radio?
Thanks,
Docfxit
Win 7 Ultimate x32, x64, Win 7 Pro x32, x64 W...
Win 7 Ultimate x32, x64, Win 7 Pro x32, x64 Win 7 Home x64, XP Pro sp3
Hello,
Seems that you've done all sorts of troubleshooting. Have you tried opening up the case and see if the card can be taken out then reseat it properly? Careful though, you don't want to damage the Motherboard. :D
Is your laptop still under warranty? Might want to call Lenovo Support.
If not, perhaps shop for a new Wi-Fi adapter.
Win7 & Win8 64bitIntel i5
Lenovo Desktop/Samsung Laptop
Win7 & Win8 64bit
Intel i5
Charter-20 Mbps
FF, IE9 and Chrome
Thanks for the reply.
Since I can put in a different hard drive and the wifi works just fine I don't see the point in resetting the card or buying a new one.
Thanks,
Docfxit
I did not see this in your initial Post, have I overlooked it?
I found the Title of your thread 'Wireless stopped working, can't power on 'wireless radio', so I thought wireless isn't working?
Win7 & Win8 64bit
Intel i5
Charter-20 Mbps
FF, IE9 and Chrome
If the card works fine on a clean install on another drive then its unlikely but still possibly a hardware fault.
Have you tried removing the lenovo connection manager and letting windows manage the connection?
Windows 7 Ultimate x64Intel Core2 Quad Q8300 2.5GhzKingston HyperX 4x1GB DDR2 1066MhzAsus/Nvidia 9500GT 1GB
Self Build
Asus P5QD Turbo
On-Board HD
22" Widescreen TFT
2x 320Gb Seagate SATAII RAID 0
2x 80Gb Seagate SATAII RAID 0
1x 1tb hybrid (8gb ssd)
650w
ATX
140mm front, 120mm Rear, 80mm Chipset + stock CPU and GPU
Plastic one
Plastic one
4Mbps
Laptop: HP Elitebook 2560p
i5 @2.7Ghz 4GB DDR3
Yes, I did see that part now....seems to be a Hard drive issue if another HDD works.
Have you done chkdsk? It might help.
Win7 & Win8 64bit
Intel i5
Charter-20 Mbps
FF, IE9 and Chrome
Yes I tried that. I have no way of powering on the WiFi then.
Thanks,
Docfxit
I put a lot of information on the one post. I can see how anyone could miss something.
I never thought of running chkdsk. That's a great idea. I'll run tomorrow.
Thanks,
Docfxit
I tried running chkdsk C: /f from a cmd window with administrator rights. I re-booted the laptop. It came up with an error running chkdsk. I tried finding the results in the event viewer but couldn't. I finally took a picture of the first part of the error. It says:
Cannot open volume for direct access.
Autochk cannot run due to an error caused by a recently installed package
I booted to a Win7 64bit CD. I ran chkdsk C: /f and it ran with no errors. But it ran very fast.
I'd like to know what is causing chkdsk not to run when it re-boots it's self.
Thanks,
Docfxit
