How to Create a "Create a System Image" Shortcut in Windows 7
InformationThis will show you how to create a Create a System Image shortcut in Windows 7.
To be able to use this shortcut, you must be logged in as an administrator.
EXAMPLE: Create a System Image
OPTION ONETo Download and Setup the "Create a System Image" Shortcut
1. Click on the Download button below to download the file below.
2. Click on Save and save the .zip file to your desktop.
3. Open the downloaded .zip file, and extract (drag and drop) all of it's contents to your desktop.
4. Right click on the extracted Create a System Image.vbs file, click on Properties, General tab, and click on the Unblock button if available.
NOTE: If you do not have a Unblock button under the General tab, then the file is already unblocked and you can continue on.
5. Right click on the now unblocked Create a System Image.vbs file, and click on Cut.
6. Navigate to C:\Windows in Windows Explorer, then right click on a empty area of the window and click on Paste to move the .vbs file here.
7. If prompted by UAC, then click on Continue and Yes.
8. Right click on the extracted Create a System Image shortcut, click on Properties, General tab, and click on the Unblock button if available.
9. You can now assign a keyboard shortcut, place in Quick Launch, or move this Create a System Image shortcut to where you like for easy use.
OPTION TWOTo Remove the "Create a System Image" Shortcut
1. Delete the Create New Backup shortcut.That's it,
2. In Windows Explorer, navigate to the .vbs file below, right click on it, and click on Delete.
C:\Windows\Create a System Image.vbs3. If prompted by UAC, then click on Yes.
Related Tutorials
- How to Create a Windows 7 "Backup User and System Files" Shortcut
- How to Create a System Image Backup in Windows 7
- How to Create a Windows 7 "Backup and Restore" Shortcut
- How to Backup User and System Files in Windows 7
- How to Do a System Image Recovery in Windows 7
- How to Enable or Disable the Ability to Create a System Image in Windows 7
- How to Make a "Create Incremental Backup" Shortcut in Windows 7 and Vista
- How to Make a "Create New Backup" Shortcut in Windows 7 and Vista
- How to Create a "Manage Windows Backup Disk Space" Shortcut in Windows 7
- How to Create a "Restore Files from Selected Backup Location" Shortcut
- How to Restore your System with a Broken Windows 7 System Image
