Page 35 of 99 FirstFirst ... 25333435363745 ... LastLast
  1. Posts : 72,058
       #340
    krash55918 said:
    I am following your instruction by going to start, all programs, accessories, right clicking command prompt and selecting "run as administrator". It takes me to a regular command prompt..C:\Users\Daniel>...according to your instructions...is should read...C:\Windows\system32...what am I doing wrong?
    Hello Krash, and welcome to Seven Forums.
    If you have UAC notifications turned on to default or above, did you get a UAC prompt after clicking on Run as administrator? If, not then it sounds like you may have clicked on Open by mistake instead of Run as administrator.
  2. Posts : 14
    Windows 7 ultimate
       #341
    Windows 7 SFC /Scannow
    I'm running Windows 7 Ultimate SP1. I'm trying to run sfc /scannow to fix a problem, but I always get "Windows Resource Protection could not start the repair service". I therefore have restarted from a Win 7 boot disk and selected Repair and the Command prompt option. I run del \windows\winsxs\pending.xml first and then sfc /scannow /offbootdir=c:\ /offwindir=c:\windows. I still get "Windows Resource Protection could not start the repair service". What should I try next?
  3. Posts : 72,058
       #342
    Hello Sluice,
    Double check to make sure that the Windows Modules Installer service is set to be enabled and Manual, then try to run SFC again to see if that may help. :)
    Services - Start or Disable
  4. Posts : 14
    Windows 7 ultimate
       #343
    Windows 7 SFC/SCANNOW
    Hi Shawn,
    Windows Modules Installer service is enabled and Manual and not started. SFC/scannow still gives the same error.
  5. Posts : 72,058
       #344
    Sluice,
    Try METHOD TWO in the tutorial below to help make sure that you have the correct drive letter while running SFC at boot to see if it will run this time around. This Windows drive is not always C at boot.
    SFC /SCANNOW : Run in Command Prompt at Boot
  6. Posts : 2
    windows 7 home premium 64bit
       #345
    problem fixed
    I was able to figure out what was going wrong...I had my security almost turned off,....thank you for all your help....krash
  7. Posts : 72,058
       #346
    That's great news Krash. I'm happy to hear that you got it sorted. :)
  8. Posts : 14
    Windows 7 ultimate
       #347
    Win 7 SFC /Scannow
    Brink said:
    Sluice,
    My boot/Windows drives are both C:. My D: drive is data only and is a separate physical drive.
  9. Posts : 72,058
       #348
    It showed these drive letter at boot using the diskpart command with "list volume"?
  10. Posts : 14
    Windows 7 ultimate
       #349
    Thanks all for your suggestions. I have done a Repair Installed Windows 7 SP1 as per Repair Install to ensure that everything is updated and working correctly. I still can't do an sfc /scannow from a DOS prompt in Windows; the same reply comes back. I have checked that Windows Module Installer is Manual and Started.
