CTRL+ALT+DEL - Require to Press to Approve UAC Elevation
    How to Require Users to Press CTRL+ALT+DEL to Approve UAC Elevation
    This will show you how to require users to have to press Control+ALT+Delete to approve or enter the administrator's password on the Secure Desktop screen for a UAC prompt to elevate a running application in Vista and Windows 7.
    If enabled, this helps to prevent a Trojan horse or other types of malicious code from stealing the user’s Windows credentials.
    You must be logged in as an administrator to be able to do this tutorial.
    EXAMPLE: Default UAC prompt
    EXAMPLE: Having to Press CTRL+ALT+DEL to Approve UAC Prompt
    OPTION ONE
    Using a REG File Download
    1. To Require Pressing CTRL+ALT+DEL to Approve UAC Prompts
    Require_CTRL+ALT+DEL_for_UAC_Elevation.reg
    B) Go to step 3.
    2. To Not Require Pressing CTRL+ALT+DEL to Approve UAC Prompts
    NOTE: This is the default setting
    Not_Require_CTRL+ALT+DEL_for_UAC_Elevation.reg
    Download
    3. Click on Save, and save the .reg file to the desktop.
    5. Click on Run, Yes (Windows 7) or Continue (Vista), Yes, and OK when prompted.
    6. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    1. Open the Local Group Policy Editor.
    2. In the left pane, click on to expand Computer Configuration, Administrative Templates, Windows Components, and Credential User Interface. (see screenshot below)
    3. In the right pane, right click on Require trusted path for credential entry and click on Edit. (see screenshot above)
    4. To Not Require Pressing CTRL+ALT+DEL to Approve UAC Prompts
    A) Select (dot) either Not Configured or Disabled. (see screenshot below step 6)
    B) Go to step 6.
    5. To Require Pressing CTRL+ALT+DEL to Approve UAC Prompts
    A) Select (dot) Enabled. (see screenshot below step 6)
    6. Click on OK. (see screenshot below)
  1. Posts : 4,566
    Windows 10 Pro
    I don't see why anyone would want to do this. But it's cool you can. I guess if your desperate for max security....
    Can you imagine having this turned on?
    That would drive me crazy!
  2. Posts : 72,052
    Especially while setting up a new installation.
  3. Posts : 4,566
    Windows 10 Pro
    That would be painful.....
    Thanks for the tutorial though :)
