Recent Items - Turn On or Off
Page 1 of 7 123 ... LastLast
    How to Turn Recent Items On or Off in Windows 7
    Recent Items is a list of your recently used files on the right side of the Start Menu, Taskbar Windows Explorer icon link, in the Navigaton Pane Recent Places, and in Jump Lists. This will show you how to turn Recent Items on or off in Windows 7.
    The hidden system folder Recent Items is located at:
    C:\Users\(User Name)\AppData\Roaming\Microsoft\Windows\Recent Items
    OR
    %AppData%\Microsoft\Windows\Recent Items
    If you go to the Recent Items folder location above and you have a yellow folder named Recent instead of one named Recent Items with an icon, then right click on the Recent folder and click Delete. Type shell:recent in the white line (Start Search) area of the Start Menu, and press Enter. Logoff and logon, or restart the computer, to rebuild the folder back to the default Recent Items. Recent Items will not function correctly if is not set as the default Recent Items folder.
    If this did not fix the Recent Items folder, then see the post at this link to make sure that the registry locations at the link have the correct locations entered for them.
    EXAMPLE: Recent Items
    NOTE: If Recent Items is turned on, the these are the locations (Taskbar, Start Menu, Navigation Pane) that you will see your recent items listed.
    OPTION ONE
    To Turn Recent Items On or Off in Start Menu Properties
    1. Right click on the Start button, and click on Properties.
    2. To Turn Recent Items On
    A) Check the Store and display recently opened items in the Start menu and the taskbar box. (see screenshot below step 4)
    NOTE: If you just turned on Recent Items, then it may take a bit after opening the recents items a few times before they actually show up.
    B) Go to step 4.
    3. To Turn Recent Items Off
    A) Uncheck the Store and display recently opened items in the Start menu and the taskbar box. (see screenshot below step 4)
    4. Click on OK. (see screenshot below)
    5. If you turned on recent items, then be sure to also set how many recent items you want displayed.
       Tip
    If you turned on recent items, and would like to have Frequent (recent items) display in the Internet Explorer taskbar jump list, then you will need to be sure to add (check) "Internet Explorer History" to the Indexed Location.
    OPTION TWO
    To Turn Recent Items On or Off using a REG File Download
    1. To Turn Recent Items On
    Turn_On_Recent_Items_in_Start_Menu.reg
    B) Go to step 3.
    2. To Turn Recent Items Off
    Turn_Off_Recent_Items_in_Start_Menu.reg
    4. Right click on the downloaded .reg file, and click on Merge.
    5. Click on Run, Yes (UAC), Yes, and OK when prompted.
    6. When done, you can delete the downloaded .reg file if you like.
    OPTION THREE
    To Add or Remove "Recent Items" Button from the Start Menu
    NOTE: This will allow you to add or remove the Recent Items button from the right dark side of the Start Menu. If you add it, then you will need to turn on Recent Items on OPTION ONE above to have them listed.
    1. Open the Start Menu Customize window.
    2. Scroll down a bit, and check the Recent Items box, and click on OK. (See screenshot below)
    3. Click on OK. (See link in step 1)
  1. Posts : 76
    windows 7
    thanks
  2. Posts : 72,106
    You're welcome Dew.
  3. Posts : 9
    win7
    im using win7 in PT-Pt language, i try to activate recent items and i cant...
    i follow all the indication but im the last step i have recent items but not the box to check it...
    can you help me please??
    tks
  4. Posts : 72,106
    Hello Win7userPT, and welcome to Seven Forums.
    Could you post a screenshot of this to see if it may help to see what may be wrong?
  5. Posts : 9
    win7
    i dont know how to put a image where...
    but the diference is the last box of recent items just isnt there, just apears Recent items and no box to check...weard!
  6. Posts : 72,106
    Umm, I have not seen that before. You might consider doing a repair install to see if it can fix it for you without losing anything.
  7. Posts : 9
    win7
    lOol... i try to uninstall the wmp that came with win7 and instal the old wmp11 i do something that the recent items apears just like i want to, but the wmp dont run... i do a restaure system and the recent items desapear again... but the wmp works fine...!
  8. Posts : 72,106
    Well, there's what happened then.
    You may need to do a clean reinstall to fix this then if it is still not working.
  9. Posts : 194
    Windows 7 RTM x86
    can u help me deleting recent search done in My Computer?
