How to Change Open Folder Icon in Windows 7 and Windows 8
This will show you how to change the active icon used to indicate which folder is expanded or opened in the Windows Explorer Navigation Pane, Start Menu All Programs, and registry folder tree to any custom icon that you want instead in Windows 7 and Windows 8.
Warning
- You can only do this while logged in to a administrator account.
- This will affect all user account's active open folder icons on the computer.
EXAMPLE: Active Open Folder
NOTE: This is the Windows Explorer navigation with the default open folder icon (left screenshot) and a custom open folder icon (right screenshot).
OPTION ONE
To Change Default Open Folder Icon
1. Press the
Windows + R keys to open the Run dialog, type
regedit, and press click/tap on
OK.
2. If prompted by UAC, then click/tap on
Yes.
3. In regedit, navigate to the location below. (see screenshot below)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer
4. In the left pane, right click on the
Explorer key, and click on
New and
Key. (See screenshot above)
5. Type
Shell Icons, and press Enter. (see screenshot below)
NOTE: If Shell Icons is already here, then you can skip steps 4 and 5.
6. In the right pane of
Shell Icons, right click on an empty space, and click on
New and
String Value. Type
4, and press Enter. (see screen shot below)
7. Double click/tap on
4 to modify it. (see screenshot above)
8. Type in the full path of the icon that you want to use as the new open folder icon. (See screenshot below)
NOTE: If you change the icon's location (path), then you must also change the location here in step 8 as well for the folder to still display that icon in Windows Explorer.
Tip
These are some good icon paths to use:
- C:\Windows\System32\shell32.dll,-290
- C:\Windows\System32\shell32.dll,-246
9. The registry will now look similar to this with your icon path under the Data column in the right pane instead. (see screenshot below)
10. Close Regedit.
11. Log off and Log on, or restart the computer to apply the new open folder icon.
OPTION TWO
To Restore Default Open Folder Icon
NOTE: This option assumes that you did OPTION ONE above to change the default folder icon.
1. Press the Windows + R keys to open the Run dialog, type regedit, and press click/tap on OK.
2. If prompted by UAC, then click/tap on Yes.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Icons
4. In the right pane of
4, and click/tap on
Delete. (See screenshot below)
5. Click/tap on
Yes. (See screenshot below)
6. Close Regedit.
7. Log off and Log on, or restart the computer to restore the default yellow open folder icon.
