Internet Options Shortcut - Create
    How to Create "Internet Options" Shortcuts in Windows
    Internet Options contains many settings to allow you to customize your browsing experience in Internet Explorer.
    This will show you how to create or download Internet Options shortcuts that can open directly to the General, Security, Privacy, Content, Connections, Programs, and Advanced tabs in Vista, Windows 7, and Windows 8.
    EXAMPLE: Internet Options - Internet Properties
    NOTE: This is the same page despite the different names that Windows 7 uses for it when opened from the Control Panel vs Internet Explorer.
    Internet Options Shortcut - Create-security.jpgInternet Options Shortcut - Create-privacy.jpg
    Internet Options Shortcut - Create-content.jpgInternet Options Shortcut - Create-connections.jpg
    Internet Options Shortcut - Create-programs.jpgInternet Options Shortcut - Create-advanced.jpg
    OPTION ONE
    To Download "Internet Options" Shortcuts
    1. Do step 2 to 8 below for what tab(s) you want the Internet Options shortcut(s) to open to.
    2. "Internet Properties" Shortcut that Opens to the General Tab
    A) Click/tap on the download button below to download the file below, and go to step 9 below.
    Internet_Options_General.zip
    3. "Internet Properties" Shortcut that Opens to the Security Tab
    Internet_Options_Security.zip
    4. "Internet Properties" Shortcut that Opens to the Privacy Tab
    Internet_Options_Privacy.zip
    5. "Internet Properties" Shortcut that Opens to the Content Tab
    Internet_Options_Content.zip
    6. "Internet Properties" Shortcut that Opens to the Connections Tab
    Internet_Options_Connections.zip
    7. "Internet Properties" Shortcut that Opens to the Programs Tab
    Internet_Options_Programs.zip
    8. "Internet Properties" Shortcut that Opens to the Advanced Tab
    Internet_Options_Advanced.zip
    9. Save the .zip file to your desktop.
    10. Open the .zip file and extract (drag and drop) the Internet Options shortcut to your desktop.
    11. Unblock the Internet Options shortcut.
    12. In Vista and Windows 7, you can now Pin to Taskbar (Windows 7 only) or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    13. In Windows 8, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    14. When done, you can delete the downloaded .zip file if you like.
    OPTION TWO
    To Manually Create "Internet Options" Shortcuts
    1. Right click on or press and hold on an empty area on your desktop, and click/tap on New and Shortcut.
    2. Copy and paste the command below into the location area for what tab you want the Internet Options shortcut to open to, and click/tap on the Next button. (see screenshot below)
    • General Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,0
    • Security Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,1
    • Privacy Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,2
    • Content Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,3
    • Connections Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,4
    • Programs Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,5
    • Advanced Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,6
    3. Type Internet Options for the name, and click/tap on the Finish button. (see screenshot below)
    4. Right click or press and hold on the new Internet Options shortcut, and click/tap on Properties.
    5. Click/tap on the Shortcut tab, then click/tap on the Change Icon button. (see screenshot below)
    6. In the line under "Look for icons in this file", copy and past the location below and press Enter. (see screenshot below)
    C:\Windows\System32\inetcpl.cpl
    7. Select the icon highlighted in blue above, and click/tap on OK. (see screenshot above)
    NOTE: You can use any icon that you would like instead though.
    8. Click/tap on OK. (see screenshot below)
    9. In Vista and Windows 7, you can now Pin to Taskbar (Windows 7 only) or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    10. In Windows 8, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
  1. Posts : 31,250
    Hi shawn,
    By the addition of an extra parameter you can open specific sub pages of the dialog
    Not sure of the full range of numbers but I think it's 0 - 6 for the 7 tabs
    Rundll32 Shell32.dll,Control_RunDLL Inetcpl.cpl,,6
    for example opens the Advanced menu
    Useful if you find yourself using one particular tab all the time
      My Computers
  2. Posts : 72,089
    Thank you Nigel. :)
  3. Posts : 824
    Windows 7 Professional 32-bit (6.1, Build 7600)
    "E:\Windows\system32\rundll32.exe" shell32.dll,Control_RunDLL inetcpl.cpl,,5
    Opens to the Programs tab but does anyone know of a way to directly open the Manage add-ons dialog?
  4. Posts : 1
    Win 7 32bit
    You guys ROCK
    I have to switch from Proxy to no proxy when I'm on my VPN at work. These shortcuts will save me a TON of time. Thank you so much!!!
  5. Posts : 72,089
    I'm happy to hear that they will help Gene. Welcome to Seven Forums. :)
  6. Posts : 2
    Windows 8 64-bit
    "%windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,4" Where can I search for this file in my computer? I've looked through "Windows\System32" but only saw "rundll32.exe" and "shell32.dll". Just want to know how to manually get the location.
  7. Posts : 72,089
    Hello knightbld098, and welcome to Seven Forums. :)
    It's to run a command to open the Internet Options control panel applet instead. There's not just a single file to run for Internet Options.
  8. Posts : 2
    Windows 8 64-bit
    Hi Brink, thanks for this thread. It is really convenient now because of this.
    Yes, I know. Already have the shortcut in my desktop. I want to know where to look for the location because when I was looking for the location itself I can't find it.
  9. Posts : 72,089
    It's not a location, but a command instead.
