Bootable ISO - Create from Installation Files
Page 1 of 6 123 ... LastLast
    How to Create a Bootable ISO from Windows 7 Installation Files
    How to EASILY make a bootable .iso file from Windows 7 or Vista Installation files with the FREE vlite.
    Vlite can be installed on 32 and 64 bit versions of XP, Vista and Windows 7.
    Homepage and Information:
       Tip
    If you got the student d/l and have 3 files :
    * Windows 7-HP-Retail-en-us-x64.exe
    * setup1.box * setup2.box
    1. Rt click each file, Properties > Unblock>Apply>OK. NOTE: Make sure read only boxes are clear
    2. Rt click and run as admin on the .exe. You will get a folder called expandedSetup on your dektop.
    If you receive this error:
    We are unable to create or save new files in the folder in which this application was downloaded. Please check the folder properties to make sure that you have security permission on the folder to write files and that the folder is not read-only.
    Continue with the tutorial to make the .iso
    Here's How:
    1. Download and Install vlite.
    vlite v1.1.6 is self contained and needs no additional applications.
    vlite v1.2 requires the large WAIK download from MS.
    It is possible to install v1.2 over the top of v1.1.6 if you wish
    2. Rt click vlite shortcut and Run as Admin. Click Install Wimfilter.
    3. Click Browse and browse to Windows Installation Files folder:
    Bootable ISO - Create from Installation Files-1-browse-2009-10-26_064124.jpg
    4. Select your Edition:
    Bootable ISO - Create from Installation Files-2-edition-2009-10-26_064516.jpg
    It takes a few seconds to load the files - then click Next.
    5. Tick Bootable .iso and click Next:
    Bootable ISO - Create from Installation Files-3-bootable.iso-2009-10-26_064643.jpg
    6. Make sure it says Create Image - and type a label if you wish. Then Click Make .iso:
    Bootable ISO - Create from Installation Files-4-create-image-2009-10-26_065018.jpg
    7. Select where to Save the .iso
    Bootable ISO - Create from Installation Files-5-save-iso-2009-10-26_065105.jpg
    After you click the Save button, vlite starts making the .iso
    Bootable ISO - Create from Installation Files-6-createiso-2009-10-26_065140.jpg
    When done, click Next
    8. EITHER - TO MAKE A BOOTABLE DVD - put an unformatted recordable dvd inthe drive and select Burn Image.
    Bootable ISO - Create from Installation Files-7-burn-image-2009-10-26_065614.jpg
    OR-TO MAKE A BOOTABLE FLASH DRIVE- click Exit and confirm - the .iso will be in the location you selected in Step 7.
    Bootable ISO - Create from Installation Files-8-close-vlite-2009-10-26_065817.jpg
       Tip
    The iso can be used to create a bootable flash drive with the Windows 7 DVD/USB Download Tool below.
    Windows 7 USB/DVD Download Tool
    Info:
  1. Posts : 1,939
    Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
    SIW2:
    Another great tutorial! Im gonna give vlite a try... its been a few years!
    I do have one suggestion to avoid confusion; I'd cut and paste the section on how to extract the expandedSetup files from the student DL again at the beginning for noobs!
    I just DL and went to install... you may want to add this image...
    And would you also add a link to my tutorial on burning a DVD or creating a bootable USB with the MS tool... Windows 7 USB/DVD Download Tool
    Thanks!
  2. Posts : 16,170
    7 X64
    I think they mostly will be doing the massive .iso download.
    Not a bad idea - just in case - will have a look at adding a note about expandedSetup folder.
      My Computers
  3. Posts : 16,170
    7 X64
    Every body seems to find this very easy - lots of views and no questions.
    Great
      My Computers
  4. Posts : 5,807
    Great
    I would have begged to differ the first few days of the tutorials regarding this and the student download files...
    It seemed like the posts were coming non-stop
  5. Posts : 16,170
    7 X64
    Hi Zi,
    Yes, there is still a lot of interest in it.
      My Computers
  6.    #6
    Thanks SIW2, this was a life saver while helping
  7. Posts : 5
    None
    Nice guide SIW2,
    Unfortunately I get an unknown error shown below:
    Vlite cant burn the ISO on the dvd for some strange reason.
    Maybe it is formatted?
    Since I dont have a flash drive (4gb+) here I have to use the 1st option.
  8. Posts : 1,797
    Windows 7 Ulti. x64
    FP09 said:
    Nice guide SIW2,
    Hello Welcome to SevenForums, Have you tried a differnt DVD- R disc. Looks like the one you are using is not recognized. Good luck to you with this problem.
  9. Posts : 5
    None
    What one should I take then?
    I only got DVD +RW. Maybe I can install xp with a flash drive en then use te data dvd to install windows 7
