Jump Lists - Change Number of Recent Items to Display
    How to Change Number of Recent Items to Display in Jump Lists in Windows 7
    This will show you how to change the number of Recent Items to display on the Start menu and taskbar pinned icon Jump Lists in Windows 7.
    On a computer that is running Windows 7 or Windows Server 2008 R2, the Jump List of an application may disappear permanently when you use the application to open or save a new item. This issue occurs when there are 999 items in the Jump List already.
    Installing the update at the link below resolves the issue and enables the displaying of the Jump Lists.
    A Jump List is not displayed in Windows 7 or in Windows Server 2008 R2 if the list contains more than 999 items
       Warning
    Recent Items will need to be turned on in order for the Start menu and taskbar pinned icons to have recent items in the Jump Lists. Turning Recent Items off will clear the Recent items in Jump Lists as well.
    EXAMPLE: Start menu and Taskbar Jump Lists
    OPTION ONE
    Through Customize Start Menu Settings
    1. Right click on the Start button and click on Properties.
    2. Click on the Customize button. (See screenshot below)
    3. Under the Start menu size section at the bottom, change the Number of recent items to display in Jump Lists to a number between 0 and 60. (See screenshot below)
    NOTE: The default number to display is 10. This setting will be grayed out if recent items is turned off.
    4. Click on OK. (See screenshot above)
    5. Click on OK. (See screenshot below step 2)
    OPTION TWO
    Manually in Registry Editor
    1. Open the Start Menu, then type regedit in the search line and press enter.
    2. In regedit, navigate to: (See screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
    3. In the right pane of Advanced, right click on Start_JumpListItems and click on Modify. (See screenshot above)
    4. Select (dot) Decimal. (See screenshot below)
    5. Enter how many (0 to 60) recent items you want displayed in Jump Lists, then click on OK. (See screensho above)
    6. Close Regedit.
  1. Posts : 9,582
    Windows 8.1 Pro RTM x64
    This can also be done directly in the registry.
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]
    "Start_JumpListItems"=dword:0000000a
    The following file simply resets this value to its default.
    Jump Lists.reg
  2. Posts : 72,062
    Thank you Dwarf. This has been added to the tutorial. :)
  3. Posts : 4
    Windows 7 Ult.
    Found a FIX for Jump List missing arrows
    I gave this a try and nothing worked.
    I spent all weekend trying to find a fix.
    I looked at my laptop which had no problems and looked at my wife's which has the problems..
    What I did was to go to this folder on my laptop called "Recent"
    Had nothing to lose
    C:\Users\asprin624\AppData\Roaming\Microsoft\Windows\Recent\
    In there are to folders called:
    AutomaticDestinations
    and
    CustomDestinations
    I copied them to my memory stick and then went to my wife's PC and replaced everything in her C:\Users\wife\AppData\Roaming\Microsoft\Windows\Recent\
    with my 2 folders.
    (removed everything before I copied the 2 folders from my Laptop to her's I made a backup on her desktop of the items and folders just to play it safe.)
    Restarted the her PC and now all the jump list arrows are back and working.
    Hope this works for others
    Asprin624
  4. Posts : 291
    Windows 3.11
    I upgraded to Windows 10 and there is no way i cant change how many items i want to see in jumplist. Will reg trick work on Windows 10?
  5. Posts : 72,062
    Hello Alija,
    I'm afraid that I haven't had a chance to test this in Windows 10 yet, but it won't harm anything to try if you like.
  6. Posts : 72,062
    Alija,
    I just tested, and it doesn't work in Windows 10.
