Taskbar Pinned Programs - Enable or Disable
Page 1 of 3 123 LastLast
    How to Enable or Disable Windows 7 Taskbar Pinned Programs
    This will allow you to enable and disable the ability for specific or all users to pin a program to the taskbar, and allow or prevent pinned programs from being shown on the taskbar for all users in Windows 7. Pin to Taskbar and pinned programs is enable by default in Windows 7.
    EXAMPLE: Taskbar with Pinned Programs Enable and Disabled
    NOTE: Top screenshot is enabled, and bottom screenshot is disabled.
    OPTION ONE
    Using a REG File Download
    1. To Enable Taskbar Pinned Programs for Only Current User
    Enable_Taskbar_Pinned_Programs.reg
    B) Go to step 3.
    2. To Disable Taskbar Pinned Programs for Only Current User
    Disable_Taskbar_Pinned_Programs.reg
    3. Click on Save, and save the .reg file to the desktop.
    4.Right click on the downloaded .reg file and click on Merge.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. When done, you can delete the downloaded .reg file if you like.
    7. Log off and log on, or restart the computer to apply.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click on to expand User Configuration, Administrative Templates, and Start Menu and Taskbar. (See screenshot below)
    3. In the right pane, right click on Remove pinned programs from the taskbar and click on Edit. (See screenshot above)
    4. To Enable Taskbar Pinned Programs
    A) Select (dot) either Not Configured or Disabled. (See screenshot below step 6)
    B) Go to step 6.
    5. To Disable Taskbar Pinned Programs
    A) Select (dot) Enabled. (See screenshot below step 6)
    6. Click on OK. (See screenshot below)
    8. Log off and log on, or restart the computer to apply.
  1. Posts : 32
    Hi...why i can't enable Windows 7 Taskbar Pinned Programs even that the Group Policy Editor are not set the 'remove pinned programs from the taskbar' to enable?
  2. Posts : 72,061
    Hello Crossnet, and welcome to Seven Forums.
    If you mean that you do not have the Pin to taskbar option in the context menu, then this is usually caused by using a XP method to remove the shortcut arrow icon instead of the proper Vista and Windows 7 method. If this may be the case, then try restoring the default shortcut arrow overlay icon using either method in the tutorial below, then see if you have the Pin to taskbar option afterwards.
    https://www.sevenforums.com/tutorials...e-restore.html
  3. Posts : 32
    Thanx for the answer. Yes, i remove the shortcut arrow icon. But i do that since i installed windows 7 for the first time about six month ago...and there is no problem with taskbar pin. But now, suddenly the taskbar pin is disappear from my windows 7 taskbar and it can't to enable/show again.
    and also i don't have the Pin to taskbar option in the context menu
  4. Posts : 72,061
    Crossnet,
    As a test, go ahead and restore the shortcut arrow using the tutorial link above to see if that restores your "pin to taskbar" option. If it does, then you can use the same tutorial to remove the shortcut arrow.
    If you removed the shortcut arrow using one of these all-in-one type tune-up/customize programs, then be sure that you do not still have it set to not have a shortcut arrow.
  5. Posts : 32
    ok..i'm gonna to try it..thank you
  6. Posts : 72,061
    You're welcome.
    If it doesn't help, then you could do a system restore using a restore point dated before you got this issue to hopefully fix it instead.
  7. Posts : 32
    i'd tried the system restore 2 days ago....it's give back the taskbar pin. But yesterday it disappear again..
  8. Posts : 72,061
    How did restoring the shortcut arrow work for you?
  9. Posts : 32
    wait momont please i can't reboot my pc now..cause i'm in doing some jobs on my pc
