Folder - Delete from Command Prompt
Page 1 of 11 123 ... LastLast
    How to Delete a Folder in Windows from the Command Prompt
    This will show you how to permanently delete a Folder in Vista, Windows 7, or Windows 8 using the RD or RMDIR command from within a command prompt.
    This can be handy if you cannot delete the folder using the normal methods.
    While you can run this command in a non-elevated or elevated command prompt, you would get the best results using a elevated command prompt.
       Warning
    The folder will be deleted immediately and not placed in the Recycle Bin first. Deleting a folder using this command will also delete all of it's contents as well as the folder. Be sure to backup anything you want to keep in the folder first.
    EXAMPLE: RD and RMDIR Command
    NOTE: You can use either the RD or RMDIR command in the command prompt. They are the same command.
    Here's How:
    1. Do step 2 or 3 below for where you would like to use a command prompt at.
    2. To Use a Elevated Command Prompt in Windows
    A) Open an Elevated command prompt in Vista/Windows 7 or Windows 8, and go to step 4 below.
    3. To Use a Command Prompt at Boot
    A) Open a command prompt at boot in Vista/Windows 7 or Windows 8, and go to step 4 below.
    B) In the command prompt, type diskpart and press Enter. (see screenshot below)
    C) In the command prompt, type list volume and press Enter. (see screenshot below)
    NOTE: This will let you see what the drive letter is for the drive that you want to delete the folder in since it may not always be the same drive letter that it is in Windows.
    D) After making note of the drive letter, type exit and press Enter. (see screenshot below)
    4. In the command prompt, type the command below and press enter.
    NOTE: Substitute Full Path of Folder within quotes below with your folder's full path within quotes instead.
    RD /S /Q "Full Path of Folder"
    NOTE: For example, if I wanted to delete a folder named Folder on my desktop, I would type this command below.
    RD /S /Q "C:\Users\UserName\Desktop\Folder"
    5. The folder should now be deleted.
    6. Close the command prompt.
    NOTE: If you used a command prompt at boot, then also close the System Recovery Options window and restart the computer.
  1. Posts : 846
    Windows 10 Pro
    Bringing back memories from 30 years ago.
    I thought everyone know that.
    DOS RULEZ!
  2. Posts : 72,058
    Hello Iggy (John ),
    Yeah, we've been having a few folks not being able to delete folders normally, so I thought this could help with that. DOS does rule. :)
  3. Posts : 93
    windows 7 ultimate was Vista home premium
    Thank you worked like a charm
  4. Posts : 10,200
    Guess it's too much to suggest to them:
    rd /s /q %userprofile%\desktop\foldername
  5. Posts : 72,058
    Hello Karl,
    For only the C:\User\(user-name) location, that would be fine.
    I just used the normal full path version since it would be a better example for all situations. Plus, the %path% may not work so well if a command prompt at boot is used. That's all. :)
  6. Posts : 10,200
    Hello Shawn,
    I agree.
    Karl
  7. Posts : 3
    windows 7 ultimate 64-bit
    great
    thanks dude.it work 100%
  8. Posts : 72,058
    You're most welcome Faridfaiz, and welcome to Seven Forums. :)
  9. Posts : 1,519
    El Capitan / Windows 10
    Brink said:
    Hello Iggy (John ),
    Arrgh! It's not DOS!!! If I try anything with Int 21h Windows 7 will not only reprimand me but ship me off to Jersey as well...
