How to Boot to the System Recovery Options in Windows 7
InformationThis will show you how to boot to the System Recovery Options screen to select the Startup Repair, System Restore, Complete PC Restore, Memory Diagnostic Tool, or Command Prompt option to use on Windows 7.NoteThe System Recovery Options menu is on the Windows 7 installation disc. If your computer manufacturer (OEM) has preinstalled recovery options, the menu might also be installed on your hard disk as a recovery partition. If your computer does not include the System Recovery Options menu, your computer manufacturer (OEM) might have customized or replaced the tool. Check the information that came with your computer or go to the manufacturer's website.
OPTION ONEUsing an OEM Recovery Partition
NOTE: This is if your computer did not come with a Windows 7 installation DVD, and has pre-installed recovery options (recovery partition) instead.
1. Start or Restart the computer.
2. Boot into the Advanced Boot Options screen.
A) Select Repair your computer and press Enter.3. Select your keyboard language preferences and click on Next. (See screeshot below).
4. Select your user name and type in the password, and then click on OK.
5. Go to step 6 in OPTION TWO below.
OPTION TWOUsing a Windows 7 Installation or System Repair Disc
1. Insert the Windows 7 installation disc, slipstream Windows 7 SP1 installation disc, or System Repair Disc into the CD/DVD drive and restart the computer.That's it,
WARNING: Check to make sure that you set the BIOS to have the CD or DVD drive listed first in the boot order.
2. If prompted, press any key to boot from the Windows 7 installation DVD. (See screenshot below)
NOTE: You will only have about 8 seconds to press this key.
3. Select your language preferences and click on Next. (See screeshot below).
4. Click on Repair your computer. (See screenshot below)
5. Select which operating system you want to restore and the click on Next. (See screenshot below)
NOTE: If Windows 7 is not listed here, or it is blank, then it is ok. Click on Next anyway.
6. Select the system recovery option you want to do. (See screenshot below)
Related Tutorials
- How to Boot to the Advanced Boot Options in Windows 7
- How to Start Windows 7 in Safe Mode
- How to Run a Startup Repair in Windows 7
- How to Do a System Restore in Windows 7
- How to Do a System Image Recovery in Windows 7
- How to Run the Memory Diagnostics Tool in Windows 7
- How to Open a Command Prompt at Startup in Windows 7
- How to Create a Windows 7 System Repair Disc
- How to See Windows 7 Reliability and Problem History with Reliability Monitor
- How to Run Disk Check in Windows 7
- How to Do a Repair Install to Fix Windows 7
- How to Create a System Recovery Shortcut in Windows 7
- How to Load SATA Drivers in Windows System Recovery Options
- How to Enable the Built-in Administrator Account from WinRE
- How to Recover from an Infinitely Looping Startup Repair Loop without Reinstalling Windows
- How to Use the Bootrec.exe Tool in Windows Recovery Environment
