Windows 7 Forums Search
Windows 7 - Pin to Taskbar and Pin to Start Menu Missing from Context Menu Fix
How to Restore Missing "Pin to Taskbar" and "Pin to Start Menu" Context Menu Items in Windows 7 Shortcuts
Published by Brink
11-30-2010
Default Pin to Taskbar and Pin to Start Menu Missing from Context Menu Fix
information   Information
If you have the Pin to Taskbar and Pin to Start Menu options missing from the context menu of shortcuts in Windows 7, then this will show you how to restore them.
Note   Note
This is usually caused by trying to remove the shortcut overlay arrow icon using the improper XP method of deleting the IsShortcut string value from the HKEY_CLASSES\ROOT\lnkfile key in the registry instead of using the proper Windows 7 method.
EXAMPLE: "Pin to Taskbar "and "Pin to Start Menu" Default and Missing
NOTE: You may also notice some context menu items appearing twice when IsShortcut is deleted.
Pin to Taskbar and Pin to Start Menu Missing from Context Menu Fix-context_menu.jpgPin to Taskbar and Pin to Start Menu Missing from Context Menu Fix-missing.jpg
Here's How:
1. Double check to make sure that you have pinning to taskbar enabled.
2. Download and merge the lnk (LNK) option in the tutorial below, then restart the computer.
Tip   Tip
If this doesn't help to restore Pin to Start Menu and Pin to Taskbar to the context menu, then see also:
Related Tutorials
Brink's Avatar
Administrator
Tutorial Tools
11-30-2010   #1
StalkeR
Windows 7 Ultimate SP1 x64
Nice tutorial Brink
Sent from my Xperia X8
11-30-2010   #2
Brink
Nice device. Thank you sir.
11-30-2010   #3
The Howling Wolves
Brink,
I think LPt was having trouble with this at one time....maybe recently.
Great Tutorial...+1
11-30-2010   #4
Brink
Thank you Dennis.
Yeah, deleting IsShortcut will cause all sorts of issues in Windows 7 and Vista.
01-02-2012   #5
monster40
Windows 7 Ultimate x32
Hello Brink,
I have a problem, here is some pics. What is going on with my pinned icons? Any idea ?
I already run these .reg files but i cant see any difference before and after their launch.
01-02-2012   #6
Brink
Hello Monster, and welcome to Seven Forums.
Could you give me a description of the issue you are having with them? I'm not sure what I'm suppose to be looking for in your screenshots.
01-02-2012   #7
monster40
Quote   Quote: Originally Posted by Brink View Post
First, sorry for my bad english
the forum is great but i cant find what i search.
do you see my pics, btw ?
i cant put any icons in the taskbar, just can't pin icons..
1. i've try to drag and drop icons to taskbar (to pin them) - failed
2. i've try to copy and paste any icons in the hidden folder (C:\users\***\appdata\roaming\microsoft\internet explorer\quick launch\user pinned\task bar) - failed
3. launch .reg files that you provide, restart the computer and try again - failed
i dont know what to do...
01-02-2012   #8
Brink
Monster,
Do you have the "Pin to Taskbar" option in the context menu of the programs you wanted to pin to the taskbar?
In your last screenshot below, change the items that are set to "Disabled" to "Not configured" to see if that may help.
01-02-2012   #9
monster40
Yes Brink,
I have "Pin to taskbar" in context menu, but it doesnt work. when i click on it.. for example - On Skype icon (not on shortcut) - it doesnt appear on taskbar, but it figure in the hidden folder
Comment
 Pin to Taskbar and Pin to Start Menu Missing from Context Menu Fix problems?
Tutorial Tools
Similar Threads for: Pin to Taskbar and Pin to Start Menu Missing from Context Menu Fix
Windows 7 Tutorial Category
Why is the context menu in Start Menu and Taskbar so small? General Discussion
Solved My Context menu/right click menu is missing help General Discussion
Pin to Start Menu - Add or Remove from Context Menu in Windows 7 Tutorials
Custom Items on Start Menu Context Menu Customization
Duplicate Context menu entries in Start menu General Discussion
