Aero Shake - Enable or Disable
    How to Enable or Disable Aero Shake in Windows 7 and Windows 8
    This tutorial will show you how to enable or disable Aero Shake for all or specific users in Windows 7 and Windows 8.
       Warning
    Aero Requirements to be Enabled in Windows 7
    NOTE: If Aero is not enabled, then Aero Shake will still not work even when enabled or turned on.
    • Aero is not included in Windows 7 Starter or Home Basic, so you must have Windows 7 Home Premium, Professional, Ultimate, or Enterprise installed.
    • 1 GHz 32-bit or 64-bit processor
    • 1 GB of system memory
    • A graphics card with support for DirectX 9 graphics with at least 128 MB of memory.
    • The graphics card must support Pixel Shader 2.0 and the Windows Display Driver Model (WDDM).
    • The Desktop Window Manager Session Manager and Themes Services need to be set as Started and Automatic.
    • You must be have True Color (32 bit) set instead of High Color (16 bit).
    • Desktop composition needs to be enabled (checked) in Visual Effects.
    • Refresh or update your WEI score.
    OPTION ONE
    To Enable or Disable "Aero Shake" using a REG File
    1. Do step 2 or 3 below for what you would like to do.
    2. To Enable Aero Shake for All Users
    A) Click/tap on the Download button below to download the file below, and go to step 4 below.
    Enable_Aero_Shake.reg
    3. To Disable Aero Shake for All Users
    Disable_Aero_Shake.reg
    4. Save the .reg file to your desktop.
    5. Double click/tap on the downloaded .reg file to merge it.
    6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.
    7. Log off and log on, or restart the computer to apply.
    8. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    To Enable or Disable "Aero Shake" in Group Policy
    2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, and Desktop. (See screenshot below)
    3. In the right pane of Desktop, double click/tap on Turn off Aero Shake window minimizing mouse gesture to edit it. (See screenshot above)
    4. Do step 5 or 6 below for what you would like to do.
    5. To Enable Aero Shake
    A) Select (dot) either Not Configured or Disabled, and go to step 7 below. (See screenshot below step 7)
    6. To Disable Aero Shake
    A) Select (dot) Enabled, and go to step 7 below. (See screenshot below step 7)
    7. Click/tap on OK. (See screenshot below)
    8. Close the Local Group Policy Editor window.
  1. Posts : 49
    Windows 7 Ultimate 64-Bit
    Why would you want to disable a feature of me?
  2. Posts : 5
    Windows 7 Home Premium 32bit.>>+ ubuntu
    thank u very much
  3. Posts : 72,058
    You're most welcome. :)
  4. Posts : 2,362
    Win7 H.Prem. 32bit+SP1
    How is it done with W7 Home Premium ?
  5. ie9
    Windows 7 Ultimate (SP1)
    The same. It'll work as long as aero works on your system
  6. Posts : 2,362
    It was how to disable I wanted.
  7. ie9
    Step 2 - For option one
    Step 5 - For option two
  8. Posts : 72,058
    You would do either one of the To Disable Aero Shake steps in either OPTION ONE or OPTION TWO to do so.
  9. Posts : 2,362
    Thank you both, I should have read it better.
