Problems with BSOD on Shutting Down or Restarting
SpardaUK
12:23 PM
Hi there
Sorry for this being my first post, I couldn't find anywhere else to go, and I couldn't figure it out myself.
I hope I cover everything here...
Windows 7 Home Premium 32bit
I think it came with my PC...
I have uploaded my results and perfmon thing
Anymore info you need, just ask :D
Hope someone can help
Thank you!
Welcome to SevenForums
Your Dump files indicate that your Avast software was the cause
Remove it using the removal tool or reinstall it
You can use MSE instead
BugCheck 1000007F, {8, 801dd000, 0, 0}
Probably caused by : aswSP.SYS ( aswSP+6f3a )
Update your Realtek drivers http://218.210.127.131/downloads/
Rt86win7.sys        0x906fc000    0x90721000    0x00025000    0x49a65b16    26/02/2009 13:04:22
Windows 10 Pro x64, Arch LinuxIntel Core 2 Quad Q8200 OC'd 3.08GHz8GB DDR2 900MhzMSI GT730 2GB GDDR5 (Kepler)
Asus Rampage formula LGA775
8GB DDR2 900Mhz
Supreme FX2
Samsung LS22F350 LED
1080P
Kingston SSDNow UV400 120GB, 500GB Hitachi, 2TB Samsung, 500GB Seagate FreeAgent, 640GB Samsung, 160GB Toshiba (Arch)
AeroCool 500W Bronze
Cooler Master V6 + 3X fans
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
Thank you for the reply, will uninstall Avast and use MSE.
Not sure what Realtek drivers I have to update, I'm guessing my Ethernet drivers because I think that is the only Realtek component on my PC?
Thank you again! :)
It's all sorted now, thank you very much! :D
8GB DDR2 900Mhz
Supreme FX2
1080P
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
