5.1 Sound Realtek HD Audio (5.1 works in settings, but not outside)
Tsuun
8:27 PM
Hi 7foums!
A lot of people seem to have this problem, however no [solved] posts seemed to fix the problem.
_________________________________
Specs & Set up:
OS: Windows 7 Ultimate x64
Motherboard: ASUS M5A99X EVO R2.0
Driver: Realtek HD R2.71 (Driver version: 6.0.1.6873)
In order to achieve 5.1 sound, I have the rear speakers connected to rear speaker out (black), center/sub to center/sub out (yellow) and then the front speakers to Front speaker out (green), and none connected to side speaker out.
To the problem:
The surround sound works perfectly when testing with 5.1 in the Realtek HD audio manager, and also in the Sound configuration. However 5.1 doesnt work anywhere else, VLC, system sounds etc, instead the sound comes from the front speakers only. I've tried every setting in VLC, but since the 5.1 doesnt work anywhere outside of configuration I assume that the problem lies somewhere else.
The settings are set to 5.1 and through speakers are placed as default, all chords are connected, and as I wrote, the sound works perfectly when testing in settings.
Does anyone have any idea what the problem is?
Tomorrow I'm going to try and rollback the drivers, but if anyone else has an idea for what I can do, please give tips. Might it be a windows 7 update issue?
For what its worth, I don't see "Speaker fill" option when I go into Settings > Sound > Speaker Properties > Enhancements, this has been listed as a solution for this problem, but I can't find it.
Sorry for the disjointed descriptions and I hope that my predicament is comprehensible, my only excuse is that I'm incredibly tired.
Windows 7 Home Premiumnot worth mentioningnot worth mentioningnot worth mentioning
Hp G62
Tsuun,
Are you using VLC for a specific reason? If everything works with your system check then it would seem you have a codec conflict. VLC is very good, and uses it's own codecs, but if you can play it without it then I would.
Is this a movie or audio file you are trying to play that does not work?
I ask because if you have working sound within windows, you can add codecs to continue using your default sound. I have used shark007 codec pack without any problems, plays all video and music files with not issue.
:ar: Shark Codec
Windows 10 Pro X64Intel(R) Core(TM) i5-3570K CPU OC@ 4.5GHZ Turbo8.00 GB DDR3 1600MhzMSI Gaming X GTX 1070
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
Realtek High Definition
Dell S23O9W, HP L1710
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
MSI DS100 Interceptor
50 down and 5 up
Chrome, IE 11
Logitech X-620 Speakers
I have been using Shark for years. No problems. Just have to watch out when you install for the toolbar BS.
Win 10 Pro 64Intel Core i7 960 @3.20 GHz24.0 GB DDR3EVGA GTX 750Ti
Win 10 Pro 64
MSI MS7522
24.0 GB DDR3
EVGA GTX 750Ti
LG E2341 23 Inch
1TB Western Dgital 1002FAEX-00Y9A0
1TB Hitachi HDS721010CLA322
700 Watt
Haf 912
Fans
Logitech MK710
Logitech M705
Cable
AIS 2015 .10.0.2225
Firefox 49
MalwareBytes Anti-Rootkit utility
Thanks for adding that Gary, I always forget to mention that!
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
50 down and 5 up
Chrome, IE 11
